WHAT WOULD U DO ?
Old Jan 2, 2006 | 05:06 PM
EK FLY's Avatar
Default WHAT WOULD U DO ?
dont really know how to start
i finish my car today ... rebuild and all that
smokes like hell it seem to be that the pistons are too small for the bore of the block and the intake gets flooded with oil , i can see oil coming out of the trottle body and all that so now i need some advice of what should i do .. reesleve it ?, compression test shows 160 on all 4 cylinders i been working on this car for abot 10 months and it really sucks to see whats happend after the first run , now my question is , is there anyway to fix this block without reesleving ..? I though about custom pistons but I thinks thats not gonna do it .....
sorry for my english
and thanks in advance
Old Jan 2, 2006 | 05:19 PM
Da K00l Aid Mayun's Avatar
Default Re: WHAT WOULD U DO ? (EGSR)
what size pistons and what bore is your block ?
Old Jan 2, 2006 | 05:34 PM
EK FLY's Avatar
Default Re: WHAT WOULD U DO ? (Da K00l Aid Mayun)
81.5 mm srp pistons ,the guy I bough the block said it was 81.5 too
one more thing the motor make a sound like the pistons were hitting the valves but its not it its the pistons moving around the slevees
Old Jan 2, 2006 | 06:50 PM
EK FLY's Avatar
up
Old Jan 2, 2006 | 06:55 PM
ksSI's Avatar
its hard to belive that u would have a 160 pounds with too small of a piston. why wouldnt you check before you assembled? and even then oil shouldnt come out of the intake becouse of that.
Old Jan 2, 2006 | 07:26 PM
asubennett's Avatar
Default Re: WHAT WOULD U DO ? (ksSI)
head gasket on upside down.
Old Jan 3, 2006 | 02:29 AM
EK FLY's Avatar
Default Re: WHAT WOULD U DO ? (asubennett)
really bc water is leaking out of the turbo and downpipe
thoes the # stamped on the headgasket have to be on the colant house going out of the head side ?
Old Jan 3, 2006 | 02:47 AM
MidShipCivic's Avatar
Wait, wait, you didnt know the exact bore of the cylinder, and you bought some pistons hoping they would fit?
Old Jan 3, 2006 | 04:44 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGSR &raquo;</TD></TR><TR><TD CLASS="quote">one more thing the motor make a sound like the pistons were hitting the valves but its not it its the pistons moving around the slevees </TD></TR></TABLE>
Piston slap. Machinist made the bore too big for the piston... the machinist was given the piston to match to the bore, along with SRP spec sheet, yes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ksSI &raquo;</TD></TR><TR><TD CLASS="quote">and even then oil shouldnt come out of the intake becouse of that.</TD></TR></TABLE>
I'm wondering if PCV system is still plumbed into the intake tract, and has no catchcan/vent.
Old Jan 3, 2006 | 04:50 AM
GaRn's Avatar
Default Re: WHAT WOULD U DO ? (J. Davis)
If there is oil in your intake, its probably your turbo blowing oil out of the compressor side, could be several reasons..
slight piston slap/noise is kinda normal with some forged pistons..
Old Jan 3, 2006 | 05:18 AM
Default Re: WHAT WOULD U DO ? (GaRn)
Piston slap with a high silicon piston, like stock or the SRP, is unacceptable.
Piston slap with a low silicon forging, like Wiseco, CP, or true JE... is barely noticeable with a professional build when engine is cold, if at all. Although the good ole boy machinist always makes yer bore a bit bigger, so she sounds like a sewing machine even when warm
Old Jan 3, 2006 | 03:11 PM
EK FLY's Avatar
Default Re: (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">Wait, wait, you didnt know the exact bore of the cylinder, and you bought some pistons hoping they would fit?</TD></TR></TABLE>
no the guys told me that both were 81.5 mml bore and pistons .. .. what would be the solution to this problem ? buy another block and bore it out to specs with the srp diameters and sizes ?
everithing on my block is new , eagles, bearing, pumps ,and all that .. do u guys think I would be able to fit all my internals into a ls block ? would I need some custom parts ?
Old Jan 3, 2006 | 03:19 PM
B16Civic93's Avatar
Default Re: (EGSR)
what block do you have now?
so let me get this straight you bought a block and pistons off a guy disassembled then took them and had it assembled at a machine shop? but didnt bother to get either checked for size to make sure that they were right?
are you sure that the turbo isnt blown and leaking oil out into your charge pipes and getting into the intake?
also what size oil feed line are you running for the turbo? and is the drain line slopped down hill? with no dips or flat spots in it?
Old Jan 3, 2006 | 04:40 PM
EK FLY's Avatar
Default Re: (B16Civic93)
no i build the block
well this is how it goes
i bough both pistons and block from the same guy ..i kinda fit the pistons into the block and I saw that the pistons were a little bit loosy and I ask him and he said that thats how u do it for a fi set up bc of the pistons they tendo to expand when they are hot .. so my gess is everithing is ok now i got everithing up and runing but having lots of oil in my intake and yes I check allready no the oil is not coming from the turbo bc i check the charge pipes and they were dry and not with oil I even check the compressor side nothing wrong with the turbo ..
Old Jan 3, 2006 | 05:08 PM
platinum00's Avatar
Default Re: (EGSR)
what does a bit loosy mean. How loose where they?
platinum.
Old Jan 3, 2006 | 05:36 PM
EK FLY's Avatar
Default Re: (platinum00)
u can move them but not too much with ur hand (pistons)
Old Jan 3, 2006 | 05:40 PM
Importordomestic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">head gasket on upside down.</TD></TR></TABLE>
Damn dude Asubennett = the man
Old Jan 4, 2006 | 09:46 AM
GaRn's Avatar
Default Re: (EGSR)
when you put the pistons in the bore, you did have rings on them right? of course they are gonna move around if you didnt have the rings on at the time..
valve lash?
Old Jan 4, 2006 | 10:03 AM
asubennett's Avatar
Default Re: (GaRn)
I'll say it again. Check your head gasket.
Old Jan 4, 2006 | 10:52 AM
mike1114's Avatar
Default Re: (asubennett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">I'll say it again. Check your head gasket. </TD></TR></TABLE>
agreed!
Old Jan 4, 2006 | 11:38 AM
GaRn's Avatar
I'm sure he saw your post the first time.
Old Jan 4, 2006 | 12:42 PM
B16Civic93's Avatar
Default Re: (GaRn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn &raquo;</TD></TR><TR><TD CLASS="quote">when you put the pistons in the bore, you did have rings on them right? of course they are gonna move around if you didnt have the rings on at the time..
valve lash?</TD></TR></TABLE>
also would like to know,
did you fit the rings? and did you check the piston to wall clearance? if so what numbers did you get?
i would have taken it to a machine shop and had everything checked.
Old Jan 4, 2006 | 12:54 PM
hondaguyef's Avatar
Is this the block that I sold you? If so, I'll chime back in and ask/answer some qusetions.
Phil
Old Jan 5, 2006 | 05:45 PM
EK FLY's Avatar
Default Re: (hondaguyef)
yea man this is it
Old Jan 5, 2006 | 05:57 PM
hondaguyef's Avatar
Default Re: (EGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGSR &raquo;</TD></TR><TR><TD CLASS="quote">yea man this is it </TD></TR></TABLE>
OK then.......
1). Did you have the machine shop size the piston/cyl wall clearance? If so, what did they tell you they set it at and did they have to bore the block any (they shouldn't have just a hone).
2). Pistons I sold you were 20 over (which is .5mm).
3) Block was sold to you w/ an 81.5mm bore.
ekVtecPower
Jun 27, 2006 11:18 AM
BokChoy
Sep 10, 2005 08:59 PM
delacampos
Dec 2, 2004 01:26 PM
RRRex
Oct 21, 2003 07:18 AM
743power
Mar 2, 2002 03:16 PM
