How to wire a Bosch 12v relay to an Inline pump.
Old Jan 26, 2002 | 08:01 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default How to wire a Bosch 12v relay to a pump.
I did a simple diagram I made for you guys. Since I have my pump under my car, and not in the engine bay, this is how I wired it up. http://www.turbomafia.com/Arturbo/relay.jpg
Hope this helps some. Come again and hope to see more of you boosting.
art
Old Jan 26, 2002 | 11:30 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: How to wire a Bosch 12v relay to a pump. (Arturbo)
ttt
Old Jan 26, 2002 | 11:33 PM
DIRep972's Avatar
Smarter than you
I heard dustin say that if the polarity is backwards it can cause the fuel pump to be really loud.. How can u tell if the polarity is backwards?
Old Jan 26, 2002 | 11:38 PM
turbocoupe's Avatar
Default Re: How to wire a Bosch 12v relay to a pump. (DIRep972)
you can get the relay for like $5.00 at any parts store. . .as long as the schematics match.
Old Jan 26, 2002 | 11:44 PM
Arturbo's Avatar
Better than steak
25 Year Member
Get a VOM and test the polarity. Dont worry chirs I have one to test your car.
Old Jan 27, 2002 | 01:15 AM
project dc2's Avatar
isnt there a pin we can tap a wire off of for this ? care to explain ? i would like to know because my brother and i usually hooked up a switch to the fuel pump and i would like to know this new form of wiring up the fuel pump, where is this wire what color is it , etcc etcc. thanks
Old Jan 27, 2002 | 01:20 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: How to wire a Bosch 12v relay to a pump. (project dc2)
Ok, I mounted my pump under the car by the rear left tire. So I tapped the Green/yellow wire on the stock pump harness to the relay(signal wire). Then I ran a 14g wire all the way to the battery fused with a 15A fuse. To me this is easier to do than getting under the dash and finding the right pin on the relay that has 4 wires the same color.
art
Old Jan 27, 2002 | 02:26 AM
is it possible that i can just get a 12V switched power source and just hook it up to that or will it overwork the system and short it out ? OR will the fuel pump be constantly turning and pressurizing as the key is in ACC or ON position? Because i know there are areas on the fuse box where you can stick spade connectors in to get a constant 12V power Source or a Switched power source.
[Modified by project dc2, 11:26 AM 1/27/2002]
Old Jan 27, 2002 | 02:34 AM
Arturbo's Avatar
Better than steak
25 Year Member
I would think you could tap it off on the extra pins on the fuse box, but I wouldnt do it. Its like hooking up an audio amp to the fuse box under the dash, you cant because of the current draw.
If you have ever worked with audio eqpt like amps, you wire a power, ground and the turn on wire from the head unit. That is the signal wire to turn the relay on/off so your amp wont always be on at all times.
art
Lmgrcivic
Apr 7, 2010 01:30 PM
crxfreak1117
Aug 15, 2009 06:09 AM
sCeRaXn
Sep 13, 2003 12:14 PM
rrei
May 12, 2003 06:02 AM
B18C-RnVA
Dec 27, 2002 06:26 PM
