What turbo should I get
Heres the story I have a b16 that is getting sleeved I am going crower rods dual rate valvesprings and ti retainers. Weisco pistons 9:5-1 compression on a stock bore stock stroke b16. I have a max rev manifold that I am thinking about replacing because I was told the numbers I would like to put down I would have to get a 60-1 and a max rev manifold wont be compatable. My horsepower goals are at least 375 to the wheels tuned on hondata s200. My question is what manifold to get that is compatable with a 60-1 that u dont have to shave the block on a b series. Please post pics if possible.
Re: (B16 BROTHER)
either go with cheapturbo.com or get a precision from Arturbo.
I believe with a precision turbo, it uses the 5 bolt so there is VERY little shaving of the block necessary, but sometimes none whatsoever.
Also, I would run an inline pro manifold if i were you.
https://honda-tech.com/zerothread?id=402894 <- good info on there
Also, here is a list of trims:
TO4E Style Compressor Cover, T3/TA34 Turbine Housing
P/N Compressor
Trim Map Turbine
Wheel A/R Turbine
Trim Retail
SC504869 50 trim T31 .48 69 $775.00
SC506376 50 trim T31 .63 76 $775.00
SC324869 54 trim T31 .48 69 $775.00
SC326376 54 trim T31 .63 76 $775.00
SC344869 57 trim T31 .48 69 $775.00
SC346376 57 trim T31 .63 76 $775.00
SC444869 60 trim T31 .48 69 $775.00
SC446376 60 trim T31 .63 76 $775.00
SC604869 60 trim T31 .48 69 $775.00
SC606376 60 trim T31 .63 76 $775.00
SC516370 60 trim T350 .63 70 $775.00
SC526376 60 trim T350 .63 76 $775.00
SC536369 60 trim T04 .63 69 $775.00
SC546369 60 trim T04 .63 69 $775.00
SC616370 56 trim Map T350 .63 69 $775.00
SC616376 56 trim Map T350 .63 69 $775.00
SC616369 56 trim Map T04 .63 69 $775.00
SC616376 56 trim Map T04 .63 76 $775.00
http://www.precisionte.com - sport compact - turbo chargers to view maps
P/N Compressor
Trim Map Turbine
Wheel A/R Turbine
Trim Retail
00bluecivicsi
11-08-2009 08:56 PM
