what tranny for turbo?
Old Dec 12, 2003 | 11:36 AM
zumH2B's Avatar
Default what tranny for turbo?
i did a search and didn't find anything. being an allmotor guy i'm new to boost. right now i have a b16 from my allmotor setup. what tranny are you guys running for your boosted cars. many suggest a ls tranny and then anothes sas a b16 or gsr..so on..so on..i just want to know what you guys are using..any help will greatly be appreciated
Old Dec 12, 2003 | 11:37 AM
DaveF's Avatar
Default Re: what tranny for turbo? (zumb18)
keep the b16 trans.
Old Dec 12, 2003 | 11:41 AM
zumH2B's Avatar
Default Re: what tranny for turbo? (2.2Lcivic)
so the gearings for the b16 is good for turbo? why b16 though? thanks for the response
Old Dec 12, 2003 | 11:42 AM
rocket256's Avatar
SI= BEST QUICK GEARS
GSR= BEST ALL AROUND
LS=BEST GAS AND HIGHWAY
rocket256's Avatar
BoostedsiR's Avatar
how much boost? keep the b16 tranny unless you are trying for like 500 hp gears would be to short with that much power
Old Dec 12, 2003 | 11:46 AM
zumH2B's Avatar
Default Re: what tranny for turbo? (BoostedsiR)
well i'm just trying to make something realistic..like 300-350whp for my setup. i guess the ls is a big NO then
Old Dec 15, 2003 | 01:03 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: what tranny for turbo? (rocket256)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket256 &raquo;</TD></TR><TR><TD CLASS="quote">SI= BEST QUICK GEARS
LS=BEST GAS AND HIGHWAY</TD></TR></TABLE>
si =great for all motor
LS= great for boost
gsr = great for all motor with nos
Old Dec 15, 2003 | 01:08 PM
Cyphear's Avatar
Theres a lot of debate about this topic. I dont think it is as straight forward as BLUE EH3 says, even though there is some truth to it. I'd go with as short of gears as possible if I were you. The only advantage to longer gears is having to shift less. The advantage to shorter gears is being more in your powerband. There is a lot of debate about this topic though. Both sides have merit. I'd keep what you have if I were you.
Old Dec 15, 2003 | 01:14 PM
99B16Si's Avatar
Default Re: what tranny for turbo? (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">
LS= great for boost
gsr = great for all motor with nos</TD></TR></TABLE>
no, no, no, no, no!!!
why does everybody think that an LS is good for boost??? i keep hearing longer gears are better because u can stay in boost longer...WRONG! the shorter the gear ratio the more the power that is transferred to the wheels and inevitably the ground. if u are having traction problems with your b16 or gsr tranny do not try to solve it by puting longer gears in your car, u may have traction with the LS but its because less power is being transferring to the ground due to the longer gears. if u cant grip get better tires.
personally i like the GSR tranny better than the b16 tho due to its everyday driveability and stronger diff.
Old Dec 15, 2003 | 01:27 PM
phiberoptik's Avatar
a little help on this debate:
https://honda-tech.com/zerothread?id=123618
https://honda-tech.com/zerothread?id=111689
Old Dec 15, 2003 | 02:58 PM
BLUE EH3's Avatar
Help we my pennies
"Staying in boost longer" means you are accelerating slower. from ..dustin
vtec-h8ter
May 5, 2005 03:27 PM
june
Feb 9, 2005 01:49 PM
Jmunk
10
Jan 20, 2005 04:37 AM
flow_azn
Dec 13, 2004 09:15 PM
DD_JonnyLee
Sep 28, 2004 02:47 PM
