What are some of the notorious issues with the Deltagate?
Old Sep 25, 2003 | 09:43 AM
WhiteSTi's Avatar
Default What are some of the notorious issues with the Deltagate?
I think mine took a ****. I don't drive it that often, but last weekend it wouldn't hold boost. I was driving on the low boost setting on my Profec B which is set at 7psi and it would go up to 10psi before I'd let off the gas. Even with the Profec B off it would boost up to 10 before letting off. Is this one of the tell tale stories of the shitty Deltagate.
Also, I forgot to mention, that it's holding boost but is erratic. It will vary between 6 and 8 psi.
Old Sep 25, 2003 | 10:24 AM
ladysman's Avatar
Default Re: What are some of the notorious issues with the Deltagate? (BoostedEX)
The only sound I know is the tinging sound they make when being thrown in a metal garbage can.
They are crap. Replace it with a Tial. youw on't regret it.
Old Sep 25, 2003 | 11:14 AM
legendboy's Avatar
Default Re: What are some of the notorious issues with the Deltagate? (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">They are crap. Replace it with a Tial. youw on't regret it.</TD></TR></TABLE>
Please elaborate? My deltagate sounds like *** but works fine...
Old Sep 25, 2003 | 11:28 AM
ladysman's Avatar
Default Re: What are some of the notorious issues with the Deltagate? (legendboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy &raquo;</TD></TR><TR><TD CLASS="quote">
Please elaborate? My deltagate sounds like *** but works fine...</TD></TR></TABLE>
They creep all the time. I had the problem switched to Tial, creep gone. Many others have had the same problem.
Old Sep 25, 2003 | 11:52 AM
InTeGrA B18b1's Avatar
i dont creep at all with my open dp with my delta
Old Sep 25, 2003 | 12:04 PM
turbo Si's Avatar
Default Re: What are some of the notorious issues with the Deltagate? (InTeGrA B18b1)
I've had mine for 3 years and have gone up to 23 psi on many ocassions with no problems. I've heard many complain, but never had any problems.
Old Sep 26, 2003 | 06:32 AM
legendboy's Avatar
Default Re: What are some of the notorious issues with the Deltagate? (turbo Si)
funny thing is lots of people with problems with the deltagate turns out they have it hooked up wrong haha
Old Sep 26, 2003 | 07:08 AM
WhiteSTi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy &raquo;</TD></TR><TR><TD CLASS="quote">funny thing is lots of people with problems with the deltagate turns out they have it hooked up wrong haha </TD></TR></TABLE>
Mine is connected correctly, it has worked fine for the past year and a half.
I'm just trying to find out if one of the problems with the Deltagate is the spring or flap freezing shut.
Old Sep 26, 2003 | 07:14 AM
DLB1994's Avatar
mine would not hold steady boost after 12psi,it started going down in high rpms
they say after 300whp they start craping out
are you guys make over 300whp on it
now i got a 35mm tial with .8bar spring
Old Sep 26, 2003 | 10:03 AM
bumsta217's Avatar
i jus got my deltagate... and i bought it used... thers 2 openings at the top.. i know one is for vacuum line... and waht do i do with the opening in the very middle?
Old Sep 26, 2003 | 10:13 AM
MotorMatrix.com's Avatar
I am a bad person
they break. they are made by turbonetics so what would anyone expect. quality has gone down hill. i have a broken one here at the shop right now. also boost creep is another issue. i wouldnt use one but if i had one i would stay around 10-14psi tops.
Old Sep 26, 2003 | 10:30 AM
JDogg's Avatar
Default Re: What are some of the notorious issues with the Deltagate? (MotorMatrix.com)
we had one crap out... at least i think its the waste gate.. we try to boost 17psi but at 5300 it drops to 10 the creeps up to 12
hell it creeps anyway, we wana run 10 but have 12 at redline
niceguysfinishlast
Mar 22, 2008 02:28 PM
ilikebigbutts
Dec 20, 2006 05:46 PM
See Are X
Oct 1, 2004 09:34 PM
Jawad.
Apr 11, 2003 01:14 PM
