what size turbo for an ls
Old Feb 15, 2004 | 01:02 PM
5STAR3's Avatar
Default what size turbo for an ls
yes i tried searching.... but it is hard when you cant use "ls"
i would like you guys to post up your turbo size/specs. what psi you run, what your WHP is and when the turbo spools up.
Thanks.
Old Feb 15, 2004 | 01:14 PM
mskibbz-T's Avatar
Default Re: what size turbo for an ls (envision2teg)
Garrett T3/T04E 60 trim 63 AR
Running at 7 PSI and am making around 240whp, full boost around 3500
Old Feb 15, 2004 | 01:15 PM
keebler65's Avatar
i agree with you that the > 3 character limit on searches sucks, however you might find more answers if you search by motor instead of trim. try "b18b". i didnt look closely at the results but it came up with a lot.
Old Feb 15, 2004 | 01:23 PM
the.hamburglar's Avatar
Default Re: what size turbo for an ls (keebler65)
is that size turbo making max horsepower at redline (6800)??
Old Feb 15, 2004 | 02:39 PM
shermanyang's Avatar
Default Re: what size turbo for an ls (hamburgler)
T3/T04E get one with a .63 ar and either a .57 or a .60 trim.
i don't have much experience with a .60 trim but i love my .57 trim and gonna stick with it until i have enough for a BB turbo.
Old Feb 16, 2004 | 12:37 AM
DownBoyDown's Avatar
Id like to know also!
Old Feb 18, 2004 | 11:55 AM
ScottFern's Avatar
Default Re: (DownBoyDown)
off topic, how reliable/long will an LS motor on 8psi last?
My friends think, if I ran that setup, I will be good for 10,000 miles and need a rebuild ????
Old Feb 18, 2004 | 11:58 AM
RedTegLS's Avatar
Default Re: (ScottFern)
The short answer to you question is there is no answer. Every motor is different. The #1 thing you can do and I mean #1 above ALL ELSE is get tuned! Get good fuel management and get a good tuner!
Old Feb 18, 2004 | 01:00 PM
BoostedSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScottFern &raquo;</TD></TR><TR><TD CLASS="quote">off topic, how reliable/long will an LS motor on 8psi last?
My friends think, if I ran that setup, I will be good for 10,000 miles and need a rebuild ????</TD></TR></TABLE>
Yup, your friends need to do a little more research. With the right tuning and a conservative amount of power you can last a lot longer than 10, 000 miles. **** i think my brother lasted 30, 000 miles on his gsr at 7psi w/ no problems. the only reason he rebuilt was for high hp.
VNTEC
Mar 18, 2004 10:06 PM
Bictorious
Mar 10, 2004 04:22 AM
*Boostwerks*
Sep 9, 2002 10:01 PM
00b18b
Nov 25, 2001 11:08 AM
