what size socket is the oil sensor thats in the back of the block ?
Old Jul 5, 2006 | 07:27 AM
95whitegizzer's Avatar
Default what size socket is the oil sensor thats in the back of the block ?
Old Jul 5, 2006 | 07:34 AM
Kowalski's Avatar
Default Re: what size socket is the oil sensor thats in the back of the block ? (95whitegizzer)
21mm
JDMSiGuy17's Avatar
Default Re: what size socket is the oil sensor thats in the back of the block ? (Kowalski)
just use an adjustable wrench....
Old Jul 5, 2006 | 07:36 AM
Default Re: what size socket is the oil sensor thats in the back of the block ? (JDMSiGuy17)
thanks
Old Jul 5, 2006 | 10:07 AM
its not 21mm anyone else???
Old Jul 5, 2006 | 10:11 AM
blown_LS's Avatar
Adjustable wrench worked for me.
Old Jul 5, 2006 | 10:42 AM
eg crunkmonster's Avatar
Default Re: what size socket is the oil sensor thats in the back of the block ? (blown_LS)
i think its a 24
Old Jul 5, 2006 | 10:51 AM
Flamenco-T's Avatar
Default Re: what size socket is the oil sensor thats in the back of the block ? (eg crunkmonster)
15/16"
Check this out..
http://www.fast-turbo.com/Imag...n.pdf
Old Jul 5, 2006 | 11:02 AM
nowtype's Avatar
Default Re: what size socket is the oil sensor thats in the back of the block ? (Flamenco-T)
23mm. I tried a 15/16" and found it to be far too loose. I know some have had sucess with that size, but not me. The metric size worked perfectly. (15/16) in = 23.8125 millimeters FYI
Old Jul 5, 2006 | 06:50 PM
Novtecdohc's Avatar
Default Re: what size socket is the oil sensor thats in the back of the block ? (nowtype)
i used a 24mm seep socket
Old Jul 5, 2006 | 08:15 PM
boosted k20's Avatar
Default Re: what size socket is the oil sensor thats in the back of the block ? (Novtecdohc)
i use a 15/16" all the time. never stripped a sensor with it
Roi
Nov 20, 2005 09:56 AM
Si Shane
Sep 14, 2005 08:00 PM
