what size injectors
Old Jun 5, 2003 | 03:15 AM
wanttorace's Avatar
Default what size injectors
ill be running a t3 on a 94 integra about 7 pounds what size injectors should i get ?
Old Jun 5, 2003 | 05:38 AM
SupaTeg's Avatar
Default Re: what size injectors (jjd493925)
first to find out you have to decide on what hp you want at the flywheel. Then you take that number and multiply it by BSFC(brake specific fuel consumption) which is for a turbo car is about .55 to .60. After you do that take the number of injectors you are using and multiply it by its duty cycle which is about 80%- 85%. now you take the answer you got from BSFC times the flywheel hp and divide it by the number you got from the injectors times the duty cycle, then you multiply it by 10.50 and you got your answer.
Example:
300 (hp you want at the crank), 4 injectors are being used, 80%(ruff estimate for the duty cycle), BSFC is about .60.
now it is (1) 300*.60 = 180, (2) 4 *0.85 = 3.4, (3) 180 / 3.2 = 56.25, (4) 56.25 * 10.50 = 590.62
So you would say you need about 600cc injectors
Old Jun 5, 2003 | 06:54 AM
ladysman's Avatar
Default Re: what size injectors (SupaTeg)
as well as a standalone to control them if you don't have one already. Hondata, AEM, etc.
Old Jun 5, 2003 | 11:34 AM
wanttorace's Avatar
Default Re: what size injectors (ladysman)
cool ill just get dsm forget doing the math
Old Jun 5, 2003 | 01:15 PM
SupaTeg's Avatar
That makes no sense because you could hurt your performance going too big.
Old Jun 5, 2003 | 01:17 PM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupaTeg &raquo;</TD></TR><TR><TD CLASS="quote">That makes no sense because you could hurt your performance going too big.</TD></TR></TABLE>
there's nothing wrong with going with a big injector...i run 720's...
Old Jun 5, 2003 | 04:30 PM
done's Avatar
Default Re: what size injectors (espano(ls))
whats the conversion, for lets say 60lb injectors, and 650cc??
what is the conversion from lb to cc??!?!?!
Old Jul 10, 2003 | 02:52 PM
HuskerHybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupaTeg &raquo;</TD></TR><TR><TD CLASS="quote">first to find out you have to decide on what hp you want at the flywheel. Then you take that number and multiply it by BSFC(brake specific fuel consumption) which is for a turbo car is about .55 to .60. After you do that take the number of injectors you are using and multiply it by its duty cycle which is about 80%- 85%. now you take the answer you got from BSFC times the flywheel hp and divide it by the number you got from the injectors times the duty cycle, then you multiply it by 10.50 and you got your answer.
Example:
So you would say you need about 600cc injectors</TD></TR></TABLE>
*in chris farley voice* That is awesome!
(runs out door to try and impress friends )
DC4_MADMAN
Oct 21, 2006 08:00 PM
See Are X
Dec 14, 2005 07:29 AM
B18 CYA
Mar 22, 2005 08:31 AM
sevret.t
Nov 23, 2004 06:39 PM
AB16A2T
Aug 30, 2002 10:02 PM
