What size injectors for 300-325whp?
Hey guys i have a 95 integra gsr with stock block pushing 7lbs of boost on a t3/t4 57trim .50 compressor/ .63 exhaust turbo. Im running DSM 440's right now I want to boost to 300-325 whp (and thats pretty much all i will go because ive read thats pretty much what stock block can handle) What sized injectors should i get 550? 650? also will the 440's hold up to 300-325whp?
Re: What size injectors for 300-325whp? (95dc2teg)
i have looked at phearble.net website and found this:
240cc = 180-190whp 310cc = 200-220whp 370cc = 220-280whp
440cc = 280-330whp 550cc = 330whp-380whp 660cc = 380whp-425whp
720cc = 425whp-475whp 880cc = 475whp-525whp 1000cc = 525whp-600whp
is this correct. because if it is then i dont need to get new injectors correct? I wanna get 300-325 whp without spending too much money, although i realize im going to need to get a 3 bar map, new wastegate spring, and walbro 255 fuel pump.
I plan on getting 300 hp and bought some 680's. 550 would be the lowest I'd go. I've seen plenty of people making 300 on 550's, but not lower.
Re: What size injectors for 300-325whp? (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">550's</TD></TR></TABLE>
I agree 550 will be plenty for ya, if your running a stock manifold and cams. My wife's old setup put down 325 whp @ 68% duty cycle w/ pump gas. 454 whp @ 90% duty cycle. w/ Red X 112octane. We were using the MSD 550 saturated injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg »</TD></TR><TR><TD CLASS="quote">i have looked at phearble.net website and found this:
is this correct. because if it is then i dont need to get new injectors correct? I wanna get 300-325 whp without spending too much money, although i realize im going to need to get a 3 bar map, new wastegate spring, and walbro 255 fuel pump.</TD></TR></TABLE>
That sounds about right. Go with 550's.
440-450 will get the job done but maxed. Its always better to run a larger injector and have room to grow. i personally tell everyone to get 1000cc's because 90% of people always go bigger in the future and there the same price as say a 650 or 750. EBAY direct from precision turbo 299 free shipping.
If you are 100% certain you will never go bigger then a 550cc should be plenty. Start with a base pressure of 50 psi. Better atomization of fuel at that pressure compared to stock.
central_driver
10
02-18-2009 09:33 PM
