What size injectors??
Old Sep 4, 2007 | 04:57 PM
gsrhatch2356's Avatar
Default What size injectors??
just bought a t3\t4 turbo kit and I am trying to get more info on what size injectors to get for gsr running 10psi of boost. and how many people run oil coolers on there set up?
Old Sep 4, 2007 | 05:57 PM
Schister66's Avatar
Man U FTW
550cc injectors will support 350whp or so....details for your setup are lacking severely but i'll assume you're going to fall short of that range
Old Sep 4, 2007 | 07:00 PM
Default Re: What size injectors?? (gsrhatch2356)
forgive me, as far as details are concerned but I really dont have much. I have a gsr in eg hatch, with 8lbs flywheel & stage 3 clutch with chipped ecu. after turbo is installed I plan on geting hondata s300 with a tune but funds are tight and are trying to get as much as I need for right now so I can go ahead and put it on without running lean. the block is stock and pretty sure stock gsr is 10:1 and have heard but correct me if I am wrong that I could run 10lbs safely without extreme damage. I also am going for a oil cooler to help with temps.
Old Sep 4, 2007 | 09:06 PM
Schister66's Avatar
Man U FTW
You wont need an oil cooler....i'm making 315whp on my stock block GSR without problems.
A few things....that 8lb fly wont be the best flywheel for a boosted car. Since you have a decent clutch in there already, i dont think you'll switch it any time soon....something to think about. You can tune w/ Crome if funds are tight. I've been using it for a while w/o problems. It isn't as nice as the other programs, but it does the trick. Finally, dont base anything on terms of PSI because that simply doesn't mean anything. If you keep your setup in the ~300whp range, you'll be safe as long as you get a good tune
Old Sep 5, 2007 | 07:46 AM
Default Re: (Schister66)
Where do I get this chrome and how much is it? and if my computer is already chipped does this effect it or do I just have to replace that chip with a progamable one?
Old Sep 5, 2007 | 07:52 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (gsrhatch2356)
http://www.tunewithcrome.com/
get a chip burner, have at it.
EK79
May 13, 2007 10:14 PM
DC2
Oct 24, 2005 01:20 PM
smurfey002
Jan 29, 2004 05:56 AM
hondaspeder
Jun 22, 2003 03:06 PM
StinkyTofu
Feb 12, 2003 08:00 PM
