Quick Q-What size injectors for 450-500hp
As the title says what size injectors will i need to run 450-500hp on my b18c wiith a t3/67 .82ar. I was thinking something like 750cc but im not sure if theyd max out.
Your advice would be appreciated thanks
Re: Quick Q-What size injectors for 450-500hp (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">750will work, but they will be maxed out....</TD></TR></TABLE>
what would u advice me to get. The reason im hesitant of going above 750cc is because i will need to add a fuuse box(correct me if im wrong)
Re: (turbo91hatch)
i was running the rc 750cc's with a walabaro 255 fuel pump and at 15 psi of boost i was already at 98 percent duty cycle close to 400whp tho, that was stock fuel pressure tho, so with a FPR i am sure that you would be fine
Re: (mo0cow)
DO NOT use over 80% of the injectors ability....the injectors will fail.....with that much HP and that much boost your motor will surely feel the rath of a failed injector (been there done that) i have 402whp and im running 1000cc....better to be safe than sorry
Re: (m R g S r)
ok so if i go something like 880cc i should be good and does any1 have a diagram for the resistor box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">yeh but too big can also cause problems, like idling etc.....</TD></TR></TABLE>
I wanna stay away from idle probs as i have my fair share of probs already
Re: (f1 vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1 vtec »</TD></TR><TR><TD CLASS="quote">ok so will i need to use a resistor box for 750+cc</TD></TR></TABLE>
It depends if they are saturated or peak and hold. Saturated doesn't need a resistor box while peak and hold does.
Re: (Marlon88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marlon88 »</TD></TR><TR><TD CLASS="quote">I have Precision 1000cc injectors and I am not running any resistors .
you're supposed to. otherwise you run a risk of frying your ecu .
also the tune i believe is slihglty effected cuz the injectors operate on diffrent scales of voltage. its the resistance inside
i belive saturated injectors operate at low voltage and have a linear voltage range to open.
whereas peak and hold. the voltages needs to spike up to get the injector open ( think. momentum) then it trims down and holds steady.
Re: (Marlon88)
get a high impedience injector and you wont need a resistor box.
if you have a low empiedence injector (DSM) you need a resistor box, if you run RC's you will not need a resistor box....if you already have a resistor box the injector company ( I know precision does) will give you the option of what ohm injector you want.....High impedience = no resistor box....Low impedience = resistor box
1 Post
Re: Quick Q-What size injectors for 450-500hp (f1 vtec)
just get 1000cc injectors if you plan to go over 400whp
better safe than sorry
the biget saturated injectors are rc750's anything bigger than that are peak and hold and need a resistor box
I post fake dyno charts
Re: Quick Q-What size injectors for 450-500hp (riceball777)
431 whp 19psi... hondata s200... rx7 550 cc injectors... accord resitor...
tell me im lying... i dont care...
with a static pressure of 60psi of fuel, 750cc's should support 500-510hp at 80% duty cylce.
With the static pressure of 43.5 (stock) you will need 900cc's to support 518-520hp at 80% duty cylce.
But remember your fuel pressure regulator is a 1:1 so you need to take that into effect. If your at base static pressure of 43.5 + 20psi of boost pressure, you should ruffly be at 60-63psi anyways.
Good Luck
Good Luck
Re: Quick Q-What size injectors for 450-500hp (JDMs1eeper)
if ive got an aeromotive fpr, then can i use the 750ccs. what would i need to increase the fuel pressure too?
It should still increase 1:1 with a positive pressure on the vacume line. (does the aeromotive have one? , cuz I have a B&M) If not, then when you tune it, Id set the base pressure at 60-65psi.
I'm running 55psi on my 1000's
Re: (miyagi)
ok soes any have a diagram or something of how to wire a resistor box up for larger injectors as afar as i know i dont think my obd1 civic comes with one?
