What should I expect from this setup:
Old Mar 17, 2004 | 06:44 PM
HondaAccordSiR's Avatar
Default What should I expect from this setup:
I've got an 2.4 Accord 2003, cars weight is down to 2800 lbs. This is i-vtec where the valves are adjusted from the line for low/mid/ and top end. Go to acura.com for a better explanation.
I'm going to try and jet for a 75 shot, but I'm worried the stock clutch will just slip. The other components have been dyno'ed for a 24 whp gain and 19 ft/lb gain. I will be taking it to the track in a couple of months when it opens (wintertime). What should I expect for a 1/4???
Here's the engine modifications to the car:
Engine/Performance:
AEM Cold Air Intake Mirror Polished
DC Sports 4-2-1 Ceramic Header
Magnaflow Catback 2.5" custom build w/ resonator & muffler, stainless steel, mandrel bent
Cat replaced with a resonator
O2 CEL Eliminator
Nitrous Express EFI Wet Kit
NOS purge valve
NX Nitrous Pressure Gauge
NX Fuel Pressure Safety Switch
MSD RPM Window Activation Switch
ZEX Hyperformance Spark Plugs
Proform Shift Light
Neuspeed Short Shift Adapter
1.25 inches removed from shifter rod
Old Mar 17, 2004 | 07:07 PM
DaveF's Avatar
Default Re: What should I expect from this setup: (HondaAccordSiR)
low 9's....offf da hizzzzy.... get a cage son
Old Mar 17, 2004 | 07:09 PM
Default Re: What should I expect from this setup: (Dturbocivic)
seriously, maybe 14's???
Old Mar 17, 2004 | 07:15 PM
BoostedSi's Avatar
low 15s, high 14s fo real YO
Old Mar 17, 2004 | 07:18 PM
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaAccordSiR &raquo;</TD></TR><TR><TD CLASS="quote">seriously, maybe 14's???</TD></TR></TABLE>
seriously, why do we get this question 3 times a day now, it should be in the rules if its not
Old Mar 17, 2004 | 07:28 PM
DaveF's Avatar
Default Re: What should I expect from this setup: (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">
seriously, why do we get this question 3 times a day now, it should be in the rules if its not </TD></TR></TABLE>
i think it is in the rules...
Old Mar 17, 2004 | 07:33 PM
tommyten's Avatar
these are the type of replies you will get when asked these type of questions
https://honda-tech.com/zerothread?id=793252
Old Mar 17, 2004 | 07:38 PM
Default Re: What should I expect from this setup: (hatchling)
everyone is a hypocrite. just wondering cause I've never messed around with nitrous before.
Old Mar 17, 2004 | 07:40 PM
I'm holding out for two more years on a turbo for the car. You should see the room between the engine and firewall. Now that honda has swapped the motor around 180 degrees.
Rabid
Feb 27, 2009 03:14 PM
shhh151
Nov 3, 2006 07:14 PM
NickW
Sep 17, 2005 09:41 PM
HondaAccordSiR
May 23, 2004 06:22 PM
Slick GS-R
Feb 21, 2002 03:49 PM
