What should I do about this compressor housing?
as you can see the inlet and outlets are flanged. a shop was going to charge me $40 a side to make adapter pipes. i thought about jbwelding a short piece of pipe to each side since it's the compressor side but i dunno how good of an idea that is. anyone wanna suggest something? btw... it's a t3 60 trim off a ford sho
ive never seen that before, but dont **** anything up by using jb weld. i repeat, dont use jb weld. ok now that we have that out of the way, dont use jb weld. find a machine shop to fabricate a plate for you, if you go the cheap way out in the beginning youll pay for it in the long run. oh ya, dont jb weld anything
$40 is what he said the local joint was going to charge ...?
Anyway, I've been wondering if the flanges on those funky turbos are just standard 2 bolt exhaust flanges....if so, they cost like $1.50 each at JC Whitney.
nah, ignore what I said and forget the whole turbo thing and sell me that puppy cheap.
Randy
Dude, give, up and sell me that turbo. Where did you find it? I have been searching the junkyards, or did you buy it new. Here is a ghetto solution: Order the exhaust flanges from JCwhitney and weld a pipe to the two flanges. Attach the flanges and a gasket to the compressor. Voila!
Randy
Randy
I can machine you plates, both plates for $40. Email or AIM for info
Josh
Josh
How much HP potential can these junkyard puppies put out in say...a SOHC 1.6L motor? I might go ghetto-fabulous and ****** me up a DIY kit as well. 8psi with the AFC hack. Think it'll work?
BTW, what manifold are you SOHC guys running with a turbo like this? Standard Drag log manifold?
pics are also here... http://www.tiora.net/~civicryda2k/?p...bo_stuff/parts
[Modified by CivicRyda2k, 9:39 AM 8/20/2002]
i have the same problem..i fixedmy problem by going to the local turbo shop here(really big on domestics) and got the actual piping from the ford with the flange on it..took it to the muffler shop. they cut it for free. and got it welded on...total cost 20 bucks
Randy
Randy
I have two of those in my room for sale. One has a .48 A/R exhaust housing, other has .63 A/R. Both are Garret (AirResearch) T3 60trims. Email me or pm me if interested.
You can find a used compressor inlet pipe and compressor outlet pipe from a RWD SR20DET T25. They use the same flanges.
People are always selling stock T25's off of the RWD SR20DET on Ebay or on http://www.thepartstrader.com
is there a possibility I could just take the compressor housing off and weld on a a 2" pipe to the outlet and a 2.5" pipe to the inlet?
Bailhatch
Jan 4, 2004 01:44 PM
legendboy
Nov 12, 2002 06:31 AM
