What are the sensors on the Back of the block!?
Old Jul 30, 2009 | 06:31 PM
kreatekustomz's Avatar
Default What are the sensors on the Back of the block!?
Just wondering what the sensors are on the back of my b18a block. There are two to the left of the oil fiter... I'm thinking of replacing them becuase they look corroded. My haynes doesnt tell me and I cant find it on acuraoemparts.com
Old Jul 30, 2009 | 07:16 PM
b20beast83's Avatar
Default Re: What are the sensors on the Back of the block!?
oil pressure sensor
and knock sensor
Old Jul 30, 2009 | 07:21 PM
thought OBD1 didnt have a knock sensor?
Old Jul 30, 2009 | 07:31 PM
grndcont's Avatar
why is this in FI?
Old Jul 30, 2009 | 08:02 PM
turbociv910's Avatar
If its an older b18b, ones and oil temp switch(2 wires,what all data says) the other is your oil dummy light.(1 wire)
94-95 gsr.
Old Sep 20, 2009 | 12:03 PM
Ok I'm bringing this back from the dead because I'm still not sure what sensors are on the back of the block.
There is an oil pressure switch (1 wire) I know for sure.
There is two other sensors I'm unsure of. The Service manual says there is an
Oil Temp Switch
ECT Switch
Knock Sensor (GSR)
one sensor I dont have a plug for. It has two plugs just like the oil pressure swtich...
Old Sep 22, 2009 | 07:16 PM
ok so what the hell are the sensors (beside the oil pressure)?
I dont even have a plug for the one with the two male prongs...
Old Sep 22, 2009 | 07:47 PM
rat city rex's Avatar
green one is oil temp, (keeps fan running when car is off to cool the motor), the male 2 pin water temp sensor.
Old Sep 23, 2009 | 08:40 AM
well I dont have those plugs on my harness... is it possible that I have an ECT soemwhere else that thats only there to plug the hole? I have one on the top left of the cylinder head and one water plug with the t-stat I believe....
Old Sep 24, 2009 | 08:44 AM
So are these sensors only located on the B18a?
Old Sep 24, 2009 | 09:06 AM
komat's Avatar
is it me or your oil T is not screw on straight
Old Sep 30, 2009 | 11:50 AM
I only threaded it like 3 turns for the picturs.
I'm having problems with my wiring harness! I'm using an OBD2 harness so I'm going to say these plugs arent going to be on the wiring harness? I know the oil pressure sensor is on the harness but I'm wondering about the Oil Temp. Sensor.
Does anyone have a Sensor/wire color documentation for wire harness tucking?
Jaz760
Apr 7, 2012 06:37 PM
LOVEthatDC2
Aug 14, 2009 11:16 PM
joedr
Nov 9, 2008 12:11 PM
Playa_FL
Mar 21, 2007 06:47 PM
h22_crx
Jan 19, 2007 03:06 PM
