what is the real way to hook a catch can?
Old Sep 26, 2001 | 08:56 PM
ILOVEGIRLS's Avatar
Default what is the real way to hook a catch can?
i know it doesnt go to the breather..does it come out of the block directly and to the can? does it still use the stock can in the back of the block? thanks
Old Sep 26, 2001 | 10:18 PM
paulzy's Avatar
Default Re: what is the real way to hook a catch can? (ILOVEGIRLS)
I wanna know too. What happens to the little black canister in the back?
Old Sep 27, 2001 | 02:42 PM
ILOVEGIRLS's Avatar
Default Re: what is the real way to hook a catch can? (Slow_ass_4dr)
yeh..i wanna know. i know somonw has to know the answer to this one.
Old Sep 27, 2001 | 05:45 PM
Double 06's Avatar
New User
here
Has to be a baffled catchcan though
Old Sep 28, 2001 | 01:21 AM
ILOVEGIRLS's Avatar
Default Re: what is the real way to hook a catch can? (Double 06)
thanks for the diag..i have a greddy catch can. is that baffled? thanks!
also..
that canister in the back has 2 holes. one from the block and the second goes to the intake manifold. the diag shows 1 hole. so do i still use that black canister? thanks!
Old Sep 28, 2001 | 02:50 AM
paulzy's Avatar
can't you just run it from the pcv to the can and plug up the manifold? Same with the crankcase too right?
Old Sep 28, 2001 | 03:37 AM
turbopanda's Avatar
I did have that piping leading from the valve cover to my turbo intake piping.. problem was that with all the high boost, it would end up sucking all the engine oil out from my engine and put it through the turbo - lots of white smoke... i simply removed that piping from the intake piping and let it hang underneath the engine. wondering if there's any harm in doing something like that..
Old Sep 28, 2001 | 06:28 AM
5 Liter Eater's Avatar
You can do that (plug up the intake) with an open setup but the diagram shows a closed setup and still uses the PCV which requires vacuum from the intake to open the valve. I am going to try removing the PCV and putting a barbed fitting in the oil seperator and running it and a hose from the breather toa vented catch can like the Jazz. This way the engine can breathe all it wants.
Old Sep 28, 2001 | 02:01 PM
ILOVEGIRLS's Avatar
Default Re: what is the real way to hook a catch can? (5 Liter Eater)
im still lost in all this catch can stuff. can anyone else clrify a bit more? thanks!
Old Sep 28, 2001 | 06:35 PM
Smashback's Avatar
Hey bud, I believe you are talking about the charcoal canister. The black tank behind the motor...that is not a catch can
Old Sep 28, 2001 | 09:36 PM
ILOVEGIRLS's Avatar
Default Re: what is the real way to hook a catch can? (mplex2000)
its the black canister that is connected to the block where pcv valve is at.
Old Sep 30, 2001 | 08:27 AM
bruthaboost's Avatar
I have the greddy unit as well and it's not baffled which sucks cause it's the baffling which catches the backstreaming oil vapors. I considering fabricating my own baffling or just stuffing it with some meshed copper, however as an unbaffled unit, don't expect much in the way as a oil trap.
HTH
Old Sep 30, 2001 | 05:57 PM
ILOVEGIRLS's Avatar
Default Re: what is the real way to hook a catch can? (b18bpwr)
how do you make it baffeled? thanks
MalcolmV8
Feb 15, 2012 04:49 PM
griz50cal
May 9, 2007 05:45 AM
311
Aug 5, 2006 12:46 PM
hOndafienD 04
Aug 2, 2004 07:00 PM
Ri5e
Aug 12, 2002 09:53 PM
