What radiator?
Old Feb 16, 2003 | 06:11 AM
B18C4-T's Avatar
Default What radiator?
I have a gsr radiator in my EG, one of the bottom mounts I made has disappeared at some point and more importantly the radiator sits right where my Jimfab.com traction bars go. I want to get either a Fluidyne or PWR radiator and was wondering where people got their radiators from, and which one works better for an EG w/a B18c and turbo.
Old Feb 16, 2003 | 06:15 AM
alpha's Avatar
Default Re: What radiator? (B18C4-T)
I was going to buy a C&R radiator from afterhourz but I have to wait as I just had work done by GEM.
https://honda-tech.com/zerothread?id=396334
Old Feb 16, 2003 | 06:16 AM
SoulSurfer's Avatar
Default Re: What radiator? (0x64)
Can't go wrong dealing with PWR from ninesecrx and Earl. They both seem like stand up guys with great prices, product, and service.
Old Feb 16, 2003 | 07:35 AM
AR Fab's Avatar
Default Re: What radiator? (LSDelSol)
CR is the best.....We use PWR stuff too...but the CR radiator is the way to go....We will soon be warehousing them for CR for the East coast..
Howard
Old Feb 16, 2003 | 09:27 AM
Farnsrocket's Avatar
Default Re: What radiator? (AR Fab)
Why are they better than PWR?
Old Feb 16, 2003 | 09:31 AM
ekb18c's Avatar
Pwr and C&R are both good products.
You can't go wrong with either or. If you are getting pwr get it from earl or ninesecrx.
[Modified by ekb18c, 7:46 PM 2/16/2003]
Old Feb 16, 2003 | 10:37 AM
Jdm_Rice_Monster's Avatar
Default Re: What radiator? (ekb18c)
I have a c and r, my friend uses pwr, both work great.
Old Feb 16, 2003 | 06:31 PM
J2turbo21's Avatar
Default Re: What radiator? (Farnsrocket)
I want to know also,i would still go with the PWR cause its an awsome price and i know there better than fluidyne which was my orginal choice.
Old Feb 16, 2003 | 06:38 PM
tony1's Avatar
Default Re: What radiator? (J2turbo21)
Honsetly, the construction of the c&r is better quality. But, realistically, both will work fine. The c&r just looks better...
Old Feb 16, 2003 | 06:52 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: What radiator? (tony1)
The C&R also comes with a thin spal fan on nicely mounted on the radiator. The spal fan is thinner than the Fal fans i beleive. The same fans used in nascar.
Old Feb 16, 2003 | 06:56 PM
ninesecrx's Avatar
Default Re: What radiator? (MotorMatrix.com)
PWR is comming out with a raciator/fan unit as well. Of course...its gonna add price. The C&R that I saw had a pretty big fan thickness wise on the back. Do they only have 1 type with 1 fan?
Old Feb 16, 2003 | 07:34 PM
Etylorcen's Avatar
Default Re: What radiator? (ninesecrx)
I got my pwr for a really good deal. It works great, no complaints here.
Old Feb 16, 2003 | 07:37 PM
tony1's Avatar
the c&r uses a very slim spal fan, i'd say a little over 1.5", but pretty big diameter.
Old Feb 16, 2003 | 07:51 PM
AR Fab's Avatar
Yes the standard CR comes with the 1.5" fan......The large CR with the Stewart water pump thats built in has a 2.5" thick fan....But hopefully that can be changed(due to the lack of space this year in our racecar)...The CR use very high quality cores also...cost is a little bit higher....and they can withstand higher pressures in case of a headgasket failure.....I have seen Fluidynes blow or swell under a bad headgasket....Actually I watched Brent Rau dyno once with a blown headgasket and watched his Fluidyne twist up and swell the tanks at a low boost setting. Our CR went through a headgasket failure at 8500rpm under 33 psi and a 150shot that eventually blew the Rad. cap off the surge tank...at closer inspection it ripped the neck off the tank! No damage to the Rad....if it did....warranty....
Didnt knock the PWR's ... these are nice
Howard
Old Feb 16, 2003 | 07:52 PM
ninesecrx's Avatar
Hmm...that is pretty tiny. Maybe the unit I saw the guy added on the fan later.
Old Feb 16, 2003 | 08:27 PM
camp1320.com's Avatar
I think AR was talking about the thickness of the Fan 1.5 inches thick.. i can Get a hold of the SPEARCO raidators whcih comes with a fan option or without. will repost with prices...
Old Feb 16, 2003 | 08:39 PM
AR Fab's Avatar
Default Re: What radiator? (camp1320.com)
thanks matrix...your right..
Howard
Old Feb 16, 2003 | 09:26 PM
B18C4-T's Avatar
ok, so where is a good place to get the radiator from. I'll probably go with PWR or C&R, if any of you are dealers please IM me with prices so I can order one. Thank you.
redzcstandardhatch
Feb 1, 2005 04:19 PM
whagkangmakulet
Jan 21, 2002 06:36 PM
