What are the pros & cons of a Log Manifold?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSi »</TD></TR><TR><TD CLASS="quote">Can anyone give me the pros and cons of a log manifold. I cant afford a equal length mani so Im picking up one of these.</TD></TR></TABLE>
You hit upon the Pro that is key for you
Affordability and great for first time/DIY projects.
Since you stated you couldn't afford an EQ/ram/etc.... just go that route and you'll be fine. Depending on B/D though... you do have options of aftermarket Cast manifolds (B) and oem HF manfolds(D).
Guest
Posts: n/a
i dont know that much just telling you what i know form past setups and hear say
pros
cheap
strong(depending on who you buy it from)
con
less flow causeing a slight loss of power.
hope that helps
pros
cheap
con
hope that helps
476 whp / 323 tq @ 17 PSI
with a log versus an equal length manifold, your turbo will spool up much quicker with the log style manifold but you will lack the stronger top end power that the equal length manifold offers. for the price, its a great manifold until you can get that equal length manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra_LSR »</TD></TR><TR><TD CLASS="quote">with a log versus an equal length manifold, your turbo will spool up much quicker with the log style manifold but you will lack the stronger top end power that the equal length manifold offers. for the price, its a great manifold until you can get that equal length manifold
You dont even know what he is using the car for. If this car is being built for the street A log manifold could be right up his alley. Most of his time will be in the lower and mid RPM Band. Id suggest and Inline Pro Manifold because you can probably find a used one cheap, they are proven, and they have a lifetime warranty. Spoollin Performance also does some nice work and people have had good things to say about phils products.
</TD></TR></TABLE>You dont even know what he is using the car for. If this car is being built for the street A log manifold could be right up his alley. Most of his time will be in the lower and mid RPM Band. Id suggest and Inline Pro Manifold because you can probably find a used one cheap, they are proven, and they have a lifetime warranty. Spoollin Performance also does some nice work and people have had good things to say about phils products.
I have an equal length that I bought about a year ago, I wish I would have went with a log now because its for a regularly driven car, and a log manifold would be fine for my ultimate 350whp goal. Better spool and less heat radiation
either way I am sure I will be plenty happy
The car will be regularly driven and Im hoping to push nothing more than 300WHP . Im planning to pick up Spooling Performance Log Manifold kit with 3" DP. From what I heard he has great mani's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSi »</TD></TR><TR><TD CLASS="quote">The car will be regularly driven and Im hoping to push nothing more than 300WHP . Im planning to pick up Spooling Performance Log Manifold kit with 3" DP. From what I heard he has great mani's.</TD></TR></TABLE>
spoolinperformance
spoolinperformance
