what is the proper way to bleed the cooling system?
Old Sep 20, 2002 | 11:32 PM
Lei Siew Long's Avatar
Default what is the proper way to bleed the cooling system?
do i fill the radiator after loosening the bleeder bolt while the engine is idling or do i fill it when the car is off? this is for a b18b.
Old Sep 21, 2002 | 05:48 AM
speedymon's Avatar
Default Re: what is the proper way to bleed the cooling system? (boostedeg6)
after filling the radiator with fresh coolant, turn the car on and let it idle till the fans come on twice. Leave the cap off and you will see bubbles come up to the top of the radiator. Keep filling till no more bubbles come up.
If i'm wrong someone correct me.
Old Sep 21, 2002 | 06:35 AM
speedworks's Avatar
Default Re: what is the proper way to bleed the cooling system? (speedymon)
open bleeder,fill radiator until antifreeze comes out of bleeder.tighten bleeder.top off radiator and start car with the cap off. let car run until both radiator hoses are hot and the cooling fan starts. reinstall cap. works every time.
Old Sep 21, 2002 | 10:28 AM
Default Re: what is the proper way to bleed the cooling system? (speedworks)
thanks guys.
Old Sep 21, 2002 | 10:43 AM
sparkz's Avatar
this way also works, since newer cars do not have the bleeder valve
halo2k7
17
Jul 23, 2008 09:57 PM
fendertool
Honda Civic (2001 - 2005)
Jul 20, 2008 11:14 PM
94gsr_vtc
12
Jul 26, 2004 08:23 AM
HondaRob
Aug 3, 2003 02:42 PM
Mag00n
Aug 1, 2003 11:07 AM
