E85 on stock fuel lines
Old May 9, 2007 | 10:02 PM
SwappedTURBOegg's Avatar
Default E85 on stock fuel lines
Ok so i just scored some bosh 1680cc injectors for cheap. so i made up my mind to run e85. im figuring i can make 450 on stock lines and a 255, and 600 with 10 an setup later on down the road.
whats the limit of power on stock lines and the limit on 1680 ccs i would really like to squeeze more power from the stock lines,than 450 so i hope im wrong. lol
Old May 9, 2007 | 10:14 PM
tony413's Avatar
the question is will the walbro support over 400hp on alcohal remember you need about 30% more alcohal to run at the same level of gas.
-6AN= up to 500 which is stock
-8AN= 500-700
-10AN= 900-1100
-12AN= insane hp
Old May 9, 2007 | 10:24 PM
Default Re: (tony413)
yes i understand that fromula. but people have made 600 on stock lines and 30% less than 600 is 420. that seems pretty weak.
Old May 9, 2007 | 10:33 PM
jdizzle!
Guest
Posts: n/a
Default Re: E85 on stock fuel lines (SwappedTURBOegg)
you will need more than a walbro for ~460+ on e85
Old May 10, 2007 | 07:16 AM
tony413's Avatar
Default Re: (SwappedTURBOegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwappedTURBOegg &raquo;</TD></TR><TR><TD CLASS="quote">yes i understand that fromula. but people have made 600 on stock lines and 30% less than 600 is 420. that seems pretty weak. </TD></TR></TABLE>
i didnt use any formula but if you want one PM me. also i havent seen any cars making 600hp on gasoline with stock lines i dont believe they can flow enough fuel. and why does it seem weak the burn rates an BTU's produced by both are different. diesel is weak for hp but the torque is unbelievable.
benefits to alcohal= no detenation, preignition, high nox, and great cooling affect when being burned.
Old May 10, 2007 | 07:45 AM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">
benefits to alcohal= no detenation, preignition, high nox, and great cooling affect when being burned. </TD></TR></TABLE>
620ish max on stock lines and walbro on gas
475ish max on stock lines and walbro E85
"diesel is weak for hp but the torque is unbelievable"
What? how can a fuel be good for torque but bad for hp?
Old May 10, 2007 | 07:48 AM
Flamenco-T's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
unless you got my fuel line kit lol...
maybe it's the QT fuel ? guaranteed gasoline hahahha
My truck makes 500 hp and 600 ft/lb...I don't understand how fuel can affect the HP but not torque...
Old May 10, 2007 | 07:50 AM
Importrev's Avatar
Default Re: (Flamenco-T)
I don't either since Hp is derived from torque based on RPM.
tony1's Avatar
It's not really the lines that are the limiting factor on my numbers, it's the pump.
Old May 10, 2007 | 07:53 AM
Flamenco-T's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">It's not really the lines that are the limiting factor on my numbers, it's the pump.</TD></TR></TABLE>
I wasn't done editing smartass...
Old May 10, 2007 | 08:52 AM
tony413's Avatar
Default Re: (tony1)
diesel releases more energy when burn than gasoline but also requires more work to burn it which is why you dont see diesels running in the 7K rpm range. also i know that the HP isnt gonna cross the TQ untill after 5252rpm which is why you see the insane TQ rating on diesels, most of them rev up to 5000. my dads cummings make around 300hp but with 550 ft/lbs of TQ
Old May 10, 2007 | 09:13 AM
bamf3000's Avatar
ya that has nothing to do with the fact that it uses diesel gas
Old May 10, 2007 | 10:29 AM
Default Re: (tony1)
</TD></TR></TABLE>and you are the man T1
Old May 10, 2007 | 10:49 AM
B18c1turboedEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">
...</TD></TR></TABLE>
Damm u guys have QT in texas? When i was there 3 weeks ago i didnt see one, i missed their egg rolls!!!
Old May 10, 2007 | 11:58 AM
purpleh22's Avatar
Default Re: (B18c1turboedEK)
Just converted to E85 this week. H22 in a 92 CX. 950cc Precision injectors, Walbro 255 + an inline pump, Cooling Mist 50/50 H2O/methanol injection that activates @ 7.5 lbs. Dynoed @ 439 whp @ 18 psi. Stock lines handled pressure & flow fine.
Old May 10, 2007 | 04:23 PM
Bailhatch's Avatar
Default Re: (purpleh22)
...or maybe diesels cant advance 'ignition' timing with rpm so they can't make high rpm Tq, so a higher peak Hp can't be made. Diesel has more energy per gram than gas or alcohol so it certainly could make big Hp, you have the engine confused with the fuel i think.
OMG B16
Apr 23, 2007 01:10 PM
.nate
Mar 27, 2006 01:37 PM
E Town DSM
May 21, 2005 09:27 PM
jisu009
Nov 28, 2003 06:03 PM
SIReg9
Sep 29, 2003 04:51 AM
