what nitrous setup should i do?
Old Jan 4, 2004 | 08:27 PM
TolnaPunk's Avatar
Default what nitrous setup should i do?
i have a 94 ls with a b18c5 , intake , exhaust, reprogrammed ecu... what nitrous setup should i look into getting? i was thinking zex but i have no idea how i should set it up.. wet? dry? window switches? what happens if my ecu has advanced timing? all suggestions are welcome !!
Old Jan 4, 2004 | 08:29 PM
baphomet's Avatar
Default Re: what nitrous setup should i do? (TolnaPunk)
I tell you fortune....fie dahlah
Old Jan 4, 2004 | 09:04 PM
joek84's Avatar
Default Re: what nitrous setup should i do? (slashDEVslashNULL)
take my direct port nitrous off me, injects fuel and nitrous evenly into intake mani. I got the tube bender for the tubes. Got an inline fuel pump too. Also stainless steel braided line for the fuel and misc fittings in addition to the whole setup to tee off fuel. Its a new nos direct port pro race fogger 4 cyl setup. Gimme an offer. I need money
Old Jan 4, 2004 | 09:08 PM
joek84's Avatar
Default Re: what nitrous setup should i do? (joek84)
you should get a window switch and a jacobs nitrous mastermind or msd digi6 to pull out timing when you spray, as well as colder injectors
Old Jan 4, 2004 | 09:43 PM
TolnaPunk's Avatar
i have msd ignition ready to put on, but what is the digi6? waht are the injectors you reccomend? and would that kit be safe on my stock internals??? thanx..
Old Jan 5, 2004 | 03:28 PM
BIG DADDY2's Avatar
IF YOU WHAT A RELIABLE DAILY DRIVER WITH INSANE POWER VERNON AT RAVER MOTORSPORTS CAN DO IT FOR YOU 1-559-733-4711 TELL THEM BIG DADDY SENT YOU
DA-MAX
Jul 13, 2005 01:59 AM
TypeR1558
Nov 13, 2003 05:12 PM
el arbi
Dec 2, 2002 01:05 PM
36Chambers
Jul 30, 2002 03:59 PM
2.2dc2
Jun 25, 2002 11:56 AM
