what fitting do i need to hook up a 1/2 inch rubber hose to a an 12 connections. please help
i'm running a a/w kit and the heatexchanger i'm using is a setrab oil cooler with an 12 connections. my only problems is i'm runnin 1/2" rubber hose for mya/w setup. so what fitting do i need for my 1/2" rubber hose so i can connect it to my an 12 connection on my setrab oil cooler. any info would help a link or a pic something need to know asap.
Re: what fitting do i need to hook up a 1/2 inch rubber hose to a an 12 connections. please help (Pr
Here ya go. I only know from my putting together my air to water setup.
http://store.summitracing.com/...10050
http://store.summitracing.com/...00112
so you want 12AN on one side of the fitting, and a barb for 1/2" hose on the other side? Or do you want 1/2" NPT on one side, and 12AN on the other side?
does it matter if i use npt or barbed. i guess just something that allows me to hook it up to a 1/2" rubber hose and has a an 12 on the other side. also those ones above will they let me connect a 1/2" rubber hose if so how?
They are hose ends, that's what they are made to do, connect a hose to a -an fitting. I looked all around for something to go from a female -an to hose barb and i could only find them in -3an and -4an. otherwise you get stuck using a couple fittings like a female -12an to femal -12an then a male -12an to male 1/2"NPT then female 1/2"NPT to hose barb. would look nasty!
http://www.fast-turbo.com/anlines.html
hey check out what i found... nifty!
http://www.jgbhose.com/Data_Re...=2123
EDIT
orrrrr... this?
http://www.jgbhose.com/Data_Re...=2125
EDIT
orrrrr... this?
the second one might be what you need, are the first two digits of the part number equal to the -an size if so then there might be one for you but it has 3/4" hose barb not 1/2". they are also 45° while your heat exchanger is most likely 37° but it would work.
is that towards me? Yeh i noticed its 45 and not 37 BUT the honda tech search engine at the bottom of the page pointed me towards it!
Ok sorry... back on track
