What is the max. piston velocity?
Old 12-02-2005, 06:41 PM
stinker504's Avatar
Default What is the max. piston velocity?
If I have a fully built bottom and head is there a theoretical max. piston velocity? I will dyno tune my car and see where the power drops off, but I want to make sure I don't over rev it.
Old 12-02-2005, 09:36 PM
stinker504's Avatar
Anyone?
Old 12-02-2005, 09:40 PM
BlueShadow's Avatar
Default Re: What is the max. piston velocity? (stinker504)
check out the link below. I started it because I wanted to switch from an LS cranked 83mm B18C to a B16A cranked 83mm B18C, basically making it into a 83mm B18b. IIRC piston speeds with b16b's are a lot slower then say an LS or LS cranked GSR because of the RS ratio, or maybe it's just the rod length, I cant remember.
https://honda-tech.com/zerothread?id=1445458
Old 12-02-2005, 10:29 PM
Better than steak
Arturbo's Avatar
Default Re: What is the max. piston velocity? (BlueShadow)
Wouldnt you need to know the mass of the pistons?
Old 12-03-2005, 03:44 AM
Sifu's Avatar
Default Re: What is the max. piston velocity? (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Wouldnt you need to know the mass of the pistons?</TD></TR></TABLE>
Dont think so, isnt it all about the length of the rod and size of the crank. From there you work out the velocity ratio and so forth??
Old 12-03-2005, 06:03 AM
z6
z6's Avatar
stroke and rpm are the only factors you need...rod lenght is irrelavant and so is piston mass.
I did however forget the formula...google it
Old 12-03-2005, 06:47 AM
stinker504's Avatar
I already know how to calculate piston velocity. That's not the problem. I don't know what the max velocity is.
I just wanted to know if there was a max piston velocity so I can carefully maximize my engine.
If no one knows then maybe someone can tell me what is the max rev on a B16 is so I can reverse engineer my answer for the F series motor?
91Honda_gsr
Engine Machining & Assembly
12-17-2015 02:21 PM
3k9civic
02-14-2006 03:35 PM
boostd ls
01-13-2006 07:58 AM
tgreaves
07-26-2004 12:17 PM
Mr. JDM-GSR
02-29-2004 11:55 AM
Quick Reply: What is the max. piston velocity?
