What max boost psi can i use on this setup?
Old May 13, 2003 | 04:14 AM
NOSED_CRX_VTEC's Avatar
Default What max boost psi can i use on this setup?
I would like to whats the max psi i can use with this setup:-
B16A1 with stock internals
TO4E/T3 Turbocharger,
Revhard manifold,
Turbosmart Ultragate 35mm wastegate,
2.5" Downpipe,
Revhard Intercooler,
Vortec blow off valve,
Stock fuel pump,
450cc DSM fuel injectors,
Afc hack,
HKS air filter,
Or could somebody tell me what i would need to run 10psi
Thanks for you help
Old May 13, 2003 | 05:51 AM
Default Re: What max boost psi can i use on this setup? (NOSED_CRX_VTEC)
Old May 13, 2003 | 05:55 AM
Boost2NA's Avatar
with a really good tune. id say 10 psi max.
Old May 13, 2003 | 06:11 AM
Default Re: What max boost psi can i use on this setup? (Boosted99Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted99Si &raquo;</TD></TR><TR><TD CLASS="quote">with a really good tune. id say 10 psi max.</TD></TR></TABLE>
Thanks for the help.
What do you mean a good tune? Like setting up the Afc.
Old May 13, 2003 | 06:14 AM
PM-Performance's Avatar
possibly 12psi .
there are too many variables. you could blow it at 5psi , make sure your motor is ok and tuned well.
Old May 13, 2003 | 06:18 AM
T-Blaze's Avatar
Hey Wassup David...
I reckon the max will be 10-11 psi but to achieve that I reckon u will need at least 2.5" Zorst all the way through and defo an after market fuel pump... I've got a uprated RS Cossie fuel pump and it holds out well.
Gimme a shout of u wanna know any more about the VAFC Hack...
Manny86
Sep 19, 2007 06:21 PM
Hatchman98
Jun 5, 2007 05:50 PM
gen4h22a
Aug 12, 2004 01:12 PM
sikcrx80
Aug 4, 2003 09:23 AM
BlackOutSi
Mar 1, 2002 04:35 PM
