What makes a turbo setup non AC compatible?
Old Sep 29, 2007 | 11:23 PM
inh's Avatar
inh
Default What makes a turbo setup non AC compatible?
Is it because the turbo hits the radiator type thing for the AC, or is it because the compressor is in the way? Whats the deal?
Old Sep 29, 2007 | 11:38 PM
ridin98civic's Avatar
Default Re: What makes a turbo setup non AC compatible? (inh)
either, or
Old Sep 29, 2007 | 11:41 PM
tony413's Avatar
#1 reason not enough engine bay space where the turbo is mounted
Old Sep 29, 2007 | 11:44 PM
inh's Avatar
inh
So usually the radiator thing for the AC (wtf is that thing called anyways?) needs to be taken out, right?
I really REALLY want AC and a gt40r in a crx with a jdm front end...
I wonder if i can relocate that to in front of the factory radiator? Maybe get a smaller one from another car..
Old Sep 29, 2007 | 11:51 PM
tony413's Avatar
Default Re: (inh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inh &raquo;</TD></TR><TR><TD CLASS="quote">So usually the radiator thing for the AC (wtf is that thing called anyways?) needs to be taken out, right?
I wonder if i can relocate that to in front of the factory radiator? Maybe get a smaller one from another car..</TD></TR></TABLE>
try using a bottom mount or some style of sidewinder manifold. i want AC too living in florida with 98* days and 80% humidity sucks *****
Old Sep 29, 2007 | 11:53 PM
inh's Avatar
inh
sidwinder.. is that where the turbo is moved over towards the passenger side of the bay? I saw a car like that before, and i think he did it to keep AC but i cant find any manifolds like that anywhere =[
Old Sep 29, 2007 | 11:54 PM
Default Re: (inh)
it would have to be custom most likely
Old Sep 29, 2007 | 11:55 PM
confucioussae's Avatar
AC compatible turbo setups mostly depend on clearance for the AC compressor. Make sure you get a manifold that places the turbo (and downpipe!) in a location where it wont bother your AC
Old Sep 30, 2007 | 12:03 AM
inh's Avatar
inh
Yea, i know custom is the way to go, i was just wondering how feasible it would be to attempt
Old Sep 30, 2007 | 12:16 AM
tony413's Avatar
Default Re: (inh)
check out RMS fab in the sponsers section of the main page under forced-induction
or lovefab
http://home.comcast.net/~chamm...1.jpg
Old Sep 30, 2007 | 02:23 AM
Doostur's Avatar
Its about da Mani
Old Sep 30, 2007 | 07:13 AM
fireman mike2288's Avatar
its the ac fan ur thiking of and sometime the condiser and all that sutff over there gets in the way of that external waste gate and the down pipe so some people usually take it out
Old Sep 30, 2007 | 03:46 PM
turbodohcsi's Avatar
A/C
3" downpipe and a t3/t67 h.o.
Modified by turbodohcsi at 12:13 AM 10/2/2007
Old Sep 30, 2007 | 04:01 PM
alex_s817's Avatar
Default Re: What makes a turbo setup non AC compatible? (turbodohcsi)
you need an ac compatible manifold for sure. i would try to get a down pipe that was designed to run with the mani and turbo so it would all line up. normally the down pipe can only be around 2.5 inches in order to clear the compressor, but 3 inch set-ups are possible in some applications but are more expensive. then the other issue is when the mani is not set-up right, the turbo could hit the ac condensor or refrigerant lines.
JurassicPark
Jun 15, 2015 08:50 AM
budomove
Feb 12, 2007 05:36 AM
tthomass
Feb 2, 2005 07:18 PM
Gfunk176
Apr 15, 2004 11:50 PM
