Replaced Radiator. Now AC Doesn't Work.
1999 Accord LX 2.3 4cyl
I'm a novice repairman, but I decided to try replacing a bad radiator myself. Took most of the day, but it worked! Car no longer overheats.
However, now my AC does not work.
When I press the AC button, I can hear the condenser fan kick on, but no cold air. I don't think the compressor is turning on.
I noticed that the AC system is right up next to the radiator. Maybe I bumped something when I was replacing the radiator and caused a leak? Or maybe it's something electrical?
Re: Replaced Radiator. Now AC Doesn't Work.
Double-checked the electrical connection to the compressor and turns out it wasn't fully seated. AC works now. Thank you.
Only issue remaining is that the radiator fan doesn't seem to want to come on. It will turn on along with the condenser fan when I turn the AC. However, when I was refilling the coolant, the service manual told me to idle the car until the radiator fan came on twice. It never did. Is this a problem?
Depending on outside temp, it can take awhile. With a cold start, I usually run my car for 15-20 minutes before the fan kicks on.
Didn't realize it would take that long for the fans to come on. I'll watch the temps, but it sounds like everything is right. Thanks guys.
cn_bb
08-09-2012 11:00 AM
