what kinda time should i run?
Old Jan 16, 2004 | 10:01 PM
spoon23_JDizM AkA SpOoN20's Avatar
Default what kinda time should i run?
98 integra ls chassis=ls head ported & polished ,full crower valvetrain with custom grinded stage 2 cams and jg gears,msd 2 step-blaster-6al-and coil,dsm 450 injectors,garret t3-t4 turbo set up with 3" dp,full 3" mandrel bent piping with 3" magna flow muffler,skunk manifold,fpr and gauge,and hondata s200...anyone.oh yea on cheater slicks..well bfgs or 555r's ?
Old Jan 16, 2004 | 10:15 PM
Lucky_Smurf's Avatar
Default Re: what kinda time should i run? (spoon20)
I'd guess based on your setup, though a whp post would help a lot, you could net ET's in the mid to low 12's maybe lower depending on what kind of driver you are.
Old Jan 17, 2004 | 12:41 AM
1.8turbolsvtec's Avatar
how much boost
Old Jan 17, 2004 | 12:52 AM
rtype11's Avatar
the only thing keeping you out of consistent low twelves is your peg leg tranny - get a diff and ill say <12.50's
Old Jan 17, 2004 | 06:02 PM
Default Re: what kinda time should i run? (rtype11)
7 pounds,for now stock bottom,and wanna add lsd and clutch kit aswell.
Old Jan 18, 2004 | 09:38 AM
up
Old Jan 18, 2004 | 03:19 PM
rtype11's Avatar
not telling you to do this but I have noticed that in Ontario (we are pretty close to sea level) that all LS can easily handle 9PSI with full factory advance on Sunoco 94 safely with your setup and even less fuel.now if your west of mason dixon your screwed for good gas and elevation so this does not apply at all.
Old Jan 18, 2004 | 11:52 PM
97ITR60's Avatar
go run it and find out
JdmEKCivic
Mar 1, 2005 09:38 AM
Integgedout
Aug 14, 2004 12:21 PM
Miz101
Aug 2, 2003 11:28 PM
Chip398193
Jan 25, 2002 05:47 AM
Chip398193
Jan 24, 2002 11:56 PM
