what kind turbo is this?
Old Nov 4, 2005 | 11:58 AM
B18 CYA's Avatar
Default what kind turbo is this?
hey all, just picked up my turbo **** here and the one on the auction says:
Garrett t3/60-1 turbo .63 a/r ... but when i compare it to an SC61 that I have sitting here, it seems a tiny bit larger. on the compressor side it says A/R .70, part # says 715583-5006 . Does any one know what kind it may be?
Old Nov 4, 2005 | 11:59 AM
Blanket Jackson's Avatar
Thats the same turbo I am trying to find out. A couple posts down.
Old Nov 4, 2005 | 12:43 PM
DRAGLS's Avatar
Default Re: what kind turbo is this? (B18 CYA)
what size housing do you have on your 61mm? E = .60a/r S= .70 a/r
count how many blades the 60-1 has? Should be 7.
Modified by DRAGLS at 5:53 PM 11/5/2005
Old Nov 4, 2005 | 01:20 PM
So whats the "name" of the turbo? Is it sufficient enough for a single cam or too big?
Old Nov 4, 2005 | 01:22 PM
DRAGLS's Avatar
Default Re: (ExcessivePerformance)
Its a Garrett model and for a single cam it may be a little laggy.
Old Nov 4, 2005 | 01:25 PM
Default Re: (DRAGLS)
Aight. Is this turbo on the garrett web page?
Old Nov 4, 2005 | 01:47 PM
B18 CYA's Avatar
ill check when i get home from work ...thanks dude
Old Nov 4, 2005 | 02:34 PM
Default Re: (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">ill check when i get home from work ...thanks dude</TD></TR></TABLE> http://www.turbobygarrett.com/...3.htm
Closest turbo on their website.
Old Nov 4, 2005 | 08:59 PM
B18 CYA's Avatar
heres 2 pics, and there are 7 blades
Old Nov 4, 2005 | 09:46 PM
SFWD 1934's Avatar
Looks like a T3/60-1 with a newer compressor housing.
-60-1 compressor wheel with a max flow rate of 61 lb/min
-0.70 AR compressor housing
-Good to 520 whp.
-Stage 3 or stage 5 turbine wheel available
-0.48, 0.63, or 0.82A/R. turbine housing available
-4 bolt standard turbine discharge
-360 degree thrust bearing.
Jason
Old Nov 4, 2005 | 09:49 PM
narfdanarf's Avatar
http://store.yahoo.com/cheapturbo/gat3w63ar.html
Old Nov 5, 2005 | 07:16 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: what kind turbo is this? (narfdanarf)
yea, its a 60-1. i would go with the sc61 personally. uses the newer gt technology for its wheels
Old Nov 5, 2005 | 09:52 AM
b16sedan's Avatar
Default Re: what kind turbo is this? (wantboost)
It really isn't an efficient use of money to swap from a 60-1 to an SC61 if he already has the 60-1, as I'm guessing the SC61 isn't his.
Old Nov 5, 2005 | 10:04 AM
B18 CYA's Avatar
yeah sc61 is my friends turbo.
Old Nov 5, 2005 | 10:59 AM
Maveric's Avatar
its a 60-1 with an s housing....good for close to 600hp....
edit..
good for a b-series
Old Nov 5, 2005 | 11:02 AM
B18 CYA's Avatar
too bad its going on an 84mm benson sleeved block haha nice edit maveric
Modified by B18 CYA at 8:28 PM 11/5/2005
Old Nov 5, 2005 | 12:03 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">yeah sc61 is my friends turbo. </TD></TR></TABLE>
my bad, i thought it was yours as well
Old Nov 5, 2005 | 12:09 PM
B18 CYA's Avatar
hehe if it was mine, i wouldn't even think twice about which one to use
Old Nov 6, 2005 | 02:59 PM
So this **** is too big for a single cam screamer?
Old Nov 6, 2005 | 08:52 PM
wantboost's Avatar
Who is Mr Robot?
stock block? built motor? specs... it all depends.. id say for a stock block you wouldnt be able to utilize the full potential of that turbo
Old Nov 8, 2005 | 08:51 AM
Sleeved, Wisecos, Eagle.....da da da on the single cam
rob...
Nov 12, 2004 10:45 PM
kell211
Mar 4, 2004 02:16 PM
boostin b16
Apr 17, 2003 02:31 PM
whagkangmakulet
Nov 13, 2001 05:21 AM
