what kind of metals are you using..
Old Mar 9, 2003 | 06:31 PM
dfoxengr's Avatar
Default what kind of metals are you using..
just curious on the types of tubular metals sizes, materials, and whatnot for welding IC piping, charge pipes, and exh. manifolds for the DIY guys...and are you bending them urself and if so where to get a pipe bender that can accomodate 3" piping...unless you use heat to bend...
Old Mar 9, 2003 | 08:43 PM
Therumblingteg's Avatar
Default Re: what kind of metals are you using.. (hybridvteceg)
People seem to be stingy with that kind of info I don’t know why? But for manifolds I use schedule 40. I get it bended at a shop because you need mandrel bent piping cause of the flow, all you need is a bunch of 90 degres. As for the ic piping I use aluminum and rubber bends cause aluminum bend are expensive, or I usually go to the exhaust shop and use exhaust piping for that.
Old Mar 10, 2003 | 02:41 AM
dfoxengr's Avatar
Default Re: what kind of metals are you using.. (Therumblingteg)
what are rubber bends>?
adseguy
Oct 4, 2004 04:07 PM
Bictorious
Feb 19, 2004 08:44 AM
BodyKits NW
Jul 22, 2003 07:25 PM
DigitalFusion
Jun 22, 2002 02:04 PM
boost killz
Sep 27, 2001 05:26 PM
