what kind of engine damage from MSD ignition failure???
Old Feb 5, 2004 | 06:42 PM
Nextelbuddy's Avatar
Default what kind of engine damage from MSD ignition failure???
what i would like to know is what would happen to my motor or what kind of damage would my motor sustain if my msd ignition box were to suddenly fail and stop working while i was boosting ?? any one have any thoughts on this? i thoguht maybe the engine woud blow from maybe detonation or something but imnot sure thats why im asking you guys
Old Feb 5, 2004 | 07:30 PM
safe driver's Avatar
you would hydrolock on fuel...
Old Feb 5, 2004 | 07:40 PM
Default Re: (safe driver)
are you serious? you really think that would happen?
Old Feb 5, 2004 | 07:42 PM
Dr Pooface's Avatar
Default Re: (nextelbuddy)
You would not hydrolock on fuel. You might backfire pretty bad though.
Old Feb 5, 2004 | 07:50 PM
doughboy247's Avatar
Default Re: what kind of engine damage from MSD ignition failure??? (nextelbuddy)
same thing happended to me.....hesistated, back-fired, and stopped. the motor was fine.
Old Feb 5, 2004 | 08:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">are you serious? you really think that would happen?</TD></TR></TABLE>
that's probably the worst case scenerio.
Old Feb 5, 2004 | 08:37 PM
15psi of fun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doughboy247 &raquo;</TD></TR><TR><TD CLASS="quote">same thing happended to me.....hesistated, back-fired, and stopped. the motor was fine.</TD></TR></TABLE>
that's what will happen if you can stay away from MSD digital 6 they are know to go out a lot.
Old Feb 5, 2004 | 08:38 PM
redboost10's Avatar
Default Re: (EFrollingout)
so what ignition do you recommend
Old Feb 5, 2004 | 09:04 PM
Default Re: what kind of engine damage from MSD ignition failure??? (doughboy247)
so if teh msd fails on me even while im boosting hard my motor will be ok? just some back firing? no engine damage?
Old Feb 5, 2004 | 09:41 PM
Johnyquest's Avatar
It shuoldn't really do anything bad... A lot of rev-limiters are spark cut rev limiters, so it'd be just like hitting a rev limiter... motor would die, no harm done.
Old Feb 6, 2004 | 05:16 AM
Default Re: what kind of engine damage from MSD ignition failure??? (Johnyquest)
ah i beleive you ar right. almost sme thing as spark cut rev limiters. thanx man
Old Feb 6, 2004 | 05:46 AM
PM-Performance's Avatar
ive had mine for like 2.5 years now and no probs
Old Feb 6, 2004 | 05:55 AM
green_GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by safe driver &raquo;</TD></TR><TR><TD CLASS="quote">you would hydrolock on fuel... </TD></TR></TABLE>
That is if you are running 1600cc injectors at 100% duty cycle on WOT at redline
Old Feb 6, 2004 | 06:32 AM
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">ive had mine for like 2.5 years now and no probs</TD></TR></TABLE>
im sure your box is fine, but i am having to replace a broken DIODE on the main board in my 6A box. unfortunately since i hav already desolderd the broken diode off the board, MSD says that they wont fix it at all. and that i have to fix it on my own. but i cant find the exact replacement i canonly find one that is rated 100 volts less. so i was going to try that one. i have looked all over the country and even out of the country. england has some but they wont even talk to me so **** it. just wanted to try this replacement part and see wat happens. the worst thing that can happen is the MSD 6 A box fail cuz the part goes out. and i the BOX fails its basically like ignition failure right??? adn if i have that the motor will just die out cortect? i wont get hydro lock from fuel? i am running 880cc injectors....
Old Feb 6, 2004 | 06:47 AM
Andrea's Avatar
The MSD fires the ignition multiple times during its firing duration. This gives a ensures that all of the products in the combustion chamber are fully burnt. If you are using a external coil it improves charging time, and discharge energy as well. The worst case scenario that can happen is that you dont fire the entire mixture in the combustion chamber, and you mis-fire. At worst you mis-fire, nothing more. Either run colder plugs, or tighten down the gap on the plug, or both. MSD boxes dont really do anything, the external coils do.
Old Feb 6, 2004 | 06:56 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: (50trim EK)
you wont misfire at all.
the car will simply shut off. I had a 94 mustang gt with a vortec setup on it and a msd setup. It decided to die on me one day on the highway. The car simply just cut off and the steering wheel and all locked up on me
coasted to a stop, spent 20 minutes figuring out what happened, bypassed my msd and it cranked right back up off the stock ignition.
If you're ever worried about it going bad just carry a spare distributor cap and stock coil with you so you can go back to stock to make it home.
Old Feb 6, 2004 | 06:57 AM
m R g S r's Avatar
Why can't MSD provide you with a replacement part??
Old Feb 6, 2004 | 07:29 AM
Default Re: (m R g S r)
they do that for a reason . they dont want other people working on them . all companies do it . ever try to fix an AMP . you can never find the exact value parts as are in it . PITA if you ask me , i gave up working on that stuff for that reason
Old Feb 6, 2004 | 09:03 AM
stackz's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Why can't MSD provide you with a replacement part?? </TD></TR></TABLE>
they do provide you with a replacement part. When my msd on my mustang went out, I simply called them up and they said to just send it in and they'd send me out a replacement ignition.
they sent me back a complete msd 6a ignition in retail box with wiring and all even though i only needed the unit itself.
only thing i paid was for shipping.
Old Feb 6, 2004 | 09:07 AM
Default Re: (stackz)
yea they will do that if u havet tampered with the inside of the unit.. i have opened the unit and took the broken diode off the board with a solderign iron. once i said that they were like nope cant help you. i was like wow. so i guess i shoudlnt have opened the box lol
Old Feb 6, 2004 | 10:12 AM
stackz's Avatar
Community Builder
thats why most things you get from companies say for you not to open them. and that's what you get for playing around with it. shaaaammmmeeeeeee on you.
"warranty void if cover removed" etc are on things for a reason
Old Feb 6, 2004 | 10:25 AM
becasue i thought i could fix it lol. and i can its so simple i just catn get the damn part lol.
Old Feb 6, 2004 | 10:32 AM
shermanyang's Avatar
so if teh msd fails on me even while im boosting hard my motor will be ok? just some back firing? no engine damage?</TD></TR></TABLE>
i've had it happen to me once...nothing bad really happens...motor just shuts down...just make sure you're not in gear for too long...you'll screw your motor up.
Old Feb 6, 2004 | 12:55 PM
Default Re: what kind of engine damage from MSD ignition failure??? (shermanyang)
yea any time my motor has ever had somethng wrong the first thing i do is press the clutch in and coast. its out of habit
CW96
Sep 9, 2007 06:37 AM
jdmturbo1127
Apr 3, 2007 11:07 AM
DaveF
Northeast (Sales)
Jan 22, 2006 06:52 AM
red civic standard
May 22, 2005 05:42 PM
SpdFrk
Aug 9, 2003 08:32 AM
