What kind of axles are good for turboed integra's??
Hey what's up? I'm in the process of building a DA6 integra from the ground up, and i have future plans of turboing it....What type of axles do you guys use? or what kind would you suggest??? thanx evan
Re: What kind of axles are good for turboed integra's?? (AGen2integra)
I did not break my first axel until this year....Ive had the swap for 4 years and two years were turbo charged. I think I broke them from wear and tear, actually the broke when I ran street tires for the first time.
Stick with the stock, if you have the money...dirveshaftshop.com
Re: What kind of axles are good for turboed integra's?? (FIxALPHA)
Ok thanx for the reply..... i was unsure if i should use the stock axles because i wasnt to certain they would hold up to a turboed motor...besides im looking to save money any way i can, but i didnt wanna cheap out on axles because they have an important job.....i hate to spend money twice if you know what i mean.
axle's break... it basically a given... there is normally something that gives... if ur making enough power... its up to u what u want to give... its either the clutch, tranny or axles
New User
Re: What kind of axles are good for turboed integra's?? (ek9t)
hint: axles are cheaper and easier to replace than clutch or tranny...
put stronger axles on and you make one of the other two things more likely to break first...
hmmmm.....
hmmmm.....
Re: What kind of axles are good for turboed integra's?? (dbman96)
i have thedriveshaftshop stage 2 axles on my teg........needless to say in the winter they arent that great, i assume that from the salt build up the CVs start to break down and in reaturn leaks for a while then blam (especially when you are in the worst place liek the side of the highway) it might just be a theory but these things arent supposed to break with air intake header and exhaust (then) so i plan on putting in a set of stock rebuilds for the winter and taking out my DSS axles and then putting then back in in the spring time.
