WHAT IS...........j&s safeguard
Old Jul 10, 2002 | 04:13 AM
Charlie Moua's Avatar
Default WHAT IS...........j&s safeguard
what's the main purpose of it. Sorry I'm a newbi to turbo.
Old Jul 10, 2002 | 04:42 AM
int3gra's Avatar
Default Re: WHAT IS...........j&s safeguard (Charlie)
http://www.jandssafeguard.com/
Old Jul 10, 2002 | 05:07 AM
Default Re: WHAT IS...........j&s safeguard (int3gra)
so all it does is have indviual cylinder timing.... right?
Old Jul 10, 2002 | 05:19 AM
int3gra's Avatar
its a knock controller ......... it listens for detonation and adjusts it accordingly.
its a safety device.
Old Jul 10, 2002 | 06:26 AM
SWEET.... i'm a real newbi when it comes to turbos.
what does it adjust? Boost ?
Old Jul 10, 2002 | 06:54 AM
len's Avatar
len
It retards the timing on your engine to prevent detonation from damaging your engine and if damage has already occured it prevents more damage from happening.
Old Jul 10, 2002 | 07:26 AM
Default Re: WHAT IS...........j&s safeguard (iloveracing)
oh....i see...... SO INSTEAD OF HAVING TO MANUALY RETARD YOUR STOCK TIMING this does it for you & according to how much detnation is occuring is any, Right?
So in way it's kinda like a really advance MSD6al ingition right?
Old Jul 10, 2002 | 08:20 AM
please confirm
Old Jul 10, 2002 | 08:30 AM
dustin's Avatar
it's reactive instead of proactive.
it tells you when you are pinging and you fix it, you don't want to just let it correct, because the motor DOES still ping for a few cycles, and then the J&S pulls timing and slowly adds it back, and if it pings again it pulls timing again, etc...
Old Jul 10, 2002 | 09:40 AM
int3gra's Avatar
Default Re: WHAT IS...........j&s safeguard (dustin)
dustin if u had a chance to buy it, would you?
i really wanted to get one a week ago but then i got alcohol injection happy.
id rather get the alcohol injection to prevent detonation now.
Old Jul 10, 2002 | 09:52 AM
Holden's Avatar
I have one and I love it. It gives me confidence to mess around with fuel and ignition settings and not have to count on my ear and right foot to save my engine from too aggressive settings.
Plus, when I'm tuning at the dragstrip, guess where detonation first starts when I've gone too lean or advanced ignition too much? 4th gear, 7000RPM, WOT. No freaking way are you going to hear detonation with all that noise.
There are two models, Classic and Ultra. The classic is just the monitor and retard unit. The ultra has all kinds of features like proactive retard that you can set with rpm and boost threshholds and a MAP signal limiter to let stock ECU's see the true MAP signal until boost is reached.
Old Jul 10, 2002 | 10:02 AM
Sonny's Avatar
Default Re: WHAT IS...........j&s safeguard (Holden)
Greg said it perfectly. I had the Ultra before Hondata, and I now have a Classic with Hondata. You sure have done a 180 with your stance on the J&S, Greg.
Sonny
Benjithx
Jan 13, 2005 11:01 AM
bmm89
Nov 21, 2004 08:17 PM
wzcb08
May 19, 2003 07:47 PM
808eg6
Jun 24, 2002 07:52 AM
IdotheSHOCKER
Jun 21, 2002 10:00 AM
