what injector clips for 780cc injectors?
Old 07-18-2005, 12:18 PM
Panoply's Avatar
Default what injector clips for 780cc injectors?
what injector clips can i use for precision 780cc injectors. the obd1 clips don't fit, just wondering if i need to get some pre obd injector clips or maybe dsm injector clips or if i can modify my existing obd1 injectors clips to fit on these. btw these are peak and hold injectors. thanks.
Old 07-18-2005, 02:04 PM
RudeLude's Avatar
Default Re: what injector clips for 780cc injectors? (Panoply)
wha kinda car do u have, i have a h22a, and the stock clips worked fine for me.....
i also have the same precision 780cc's in there
Old 07-18-2005, 04:32 PM
drumking15's Avatar
they will indeed fit...you have to cut the inside of the injectors for the clips to slide in...use an exacto knife or razor blade....
btw they use obd 1 clips...and make sure you have a resistor pack in there before tryin anything w/ those
Old 07-18-2005, 05:16 PM
Panoply's Avatar
Default Re: (drumking15)
okay cool. yeah i knew about the resistor box. just didn't know if i could find some injector clips that didn't need modifying. what year injector clips are you using rudelude? thanks for the info.
Old 07-19-2005, 01:37 PM
RudeLude's Avatar
Default Re: (Panoply)
pm'd
BoostinTEG
01-19-2011 11:17 AM
jchrm80
11-05-2007 01:21 PM
.adam.
08-16-2006 11:16 AM
petergriffen
07-17-2006 08:48 AM
Panoply
07-18-2005 09:36 AM
Quick Reply: what injector clips for 780cc injectors?
