What headgasket to use.
Old Jan 26, 2005 | 11:20 AM
TheThiefTheKnife'NTheGun's Avatar
Default What headgasket to use.
I am curious what head gaskets people run.. I am doing a build right now plan on running 14-17 psi, this is my first honda build I have been building dsms for years and always use cometic but I have heard of people blowing alot of them out on hondas what brand should I use and how thick.. thanks
Old Jan 26, 2005 | 11:21 AM
EGfastback22R's Avatar
Default Re: What headgasket to use. (justinwipf)
I heard the inline-pro low compression ultra thick gasket is virtually unblowable.
Old Jan 26, 2005 | 11:27 AM
Thanks.. I looked at theres and they require adjustable cam gears that is something that I am running without. so that is a no go for me..
Old Jan 26, 2005 | 12:18 PM
DaX's Avatar
DaX
Loved
Community Favorite
OEM w/ ARP studs.
Old Jan 26, 2005 | 12:23 PM
beerbongskickass's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">OEM w/ ARP studs. </TD></TR></TABLE>
That's what I use.
Old Jan 26, 2005 | 12:41 PM
donkiman's Avatar
all the shops around here prefer oem
Old Jan 26, 2005 | 12:52 PM
Ri5e's Avatar
OEM is good.
Old Jan 26, 2005 | 02:37 PM
rmcdaniels's Avatar
I use a Cometic MLS on a 8.4:1 B16 running a little over 20 PSI of boost
Old Jan 26, 2005 | 06:24 PM
QuickEJ6's Avatar
Default Re: (rmcdaniels)
OEM and ARP Studs on a B18b &lt;&lt;
Old Jan 26, 2005 | 06:54 PM
DefiantGSR's Avatar
Default Re: (QuickEJ6)
OEM headgasket and OEM studs. You won't have a problem with OEM head bolts. People usually do it for a "peace of mind."
Old Jan 27, 2005 | 05:46 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (DefiantGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR &raquo;</TD></TR><TR><TD CLASS="quote">OEM headgasket and OEM studs. You won't have a problem with OEM head bolts. People usually do it for a "peace of mind."</TD></TR></TABLE>
I did. Lifted the head under boost and blew out the HG.
Old Jan 27, 2005 | 06:31 AM
platinum00's Avatar
Default Re: (DaX)
OEM
platinum.
PrecisionH23a's Avatar
You will have a problem if you re-use them. This is because of bolt stretch that occurs when the bolt is torqued then removed.
I'm also a fan of the OEM gasket with ARP's. The good thing about ARP's is that you can use them time and time again. You can try your luck with re-using stock head bolts and you may get lucky. Or you may be like the other people that blew their headgaskets due to the head lifting like Dax pointed out.
Old Jan 27, 2005 | 08:18 AM
SOHC_MShue's Avatar
oem and arp's here ...i still blow headgaskets like a biatch though . My block probably isn't straight though.
Old Jan 27, 2005 | 08:33 AM
COLORPROS's Avatar
Default Re: What headgasket to use. (SOHC_MShue)
I say use headstuds and the Cometic...Thats what Earl recomended to me and ill be running over 30psi
ProPerformance
Jun 16, 2007 08:25 AM
jarven093
Mar 3, 2007 10:39 PM
H22Luda720
Mar 6, 2006 07:13 PM
JDMSi92
Nov 29, 2005 05:29 AM
JDMTurboCivic11
Oct 22, 2004 06:51 AM
