what headgasket?
Old Oct 29, 2005 | 07:20 AM
zbaber's Avatar
Default what headgasket?
ok.. im thinking about going with a mr. gasket stackable, or an apexi headgasket... i think i fried another stock on... on my ls turbo..
any others i should consider?
Old Oct 29, 2005 | 07:29 AM
non-VTEC's Avatar
Default Re: what headgasket? (zbaber)
the OEM gasket is best.
Old Oct 29, 2005 | 09:07 AM
Metzler's Avatar
Default Re: what headgasket? (non-VTEC)
cometic (.040") turbo headgasket
Old Oct 29, 2005 | 09:59 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: what headgasket? (Metzler)
i would say o.e or cometic. i went cometic.
Old Oct 29, 2005 | 12:16 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zbaber &raquo;</TD></TR><TR><TD CLASS="quote">ok.. im thinking about going with a mr. gasket stackable, or an apexi headgasket... i think i fried another stock on... on my ls turbo..
If you keep blowing headgaskets, fix the underlying issue. If it was installed properly (ie. torqued properly and head/deck surfaces are flat) then there is no reason it would blow other than the tune.
Old Oct 29, 2005 | 04:54 PM
whoneedzvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metzler &raquo;</TD></TR><TR><TD CLASS="quote">cometic (.040") turbo headgasket</TD></TR></TABLE>
is this supposed to be a high boost/heavy duty head gasket?
Old Oct 29, 2005 | 06:09 PM
zbaber's Avatar
Default Re: what headgasket? (nfn15037)
turns out i didnt blow it... dont really know what the smoke is from yet.. although its oil.. either fried turbo seals..( most likely it) or rings.. but im straying from it being the rings... just tested compressino a week or so ago.. and it showed around 190-195 all the way across
Old Oct 29, 2005 | 06:30 PM
NJIN BUILDR's Avatar
Check your turbo oil drain.The line maybe kinked or obstructed.
Glenn
Old Oct 29, 2005 | 06:51 PM
zbaber's Avatar
Default Re: what headgasket? (NJIN BUILDR)
ya.. i was gonna look into that next... i know its not as perfect as it could be... im looking for a new oil pan so i can redo my return line
blinx9900
Nov 11, 2006 10:40 AM
95dc2teg
Jul 17, 2006 01:26 PM
ssrcx94
Dec 18, 2005 10:05 AM
topspeed86
Jan 6, 2005 05:18 PM
4-banging
Mar 15, 2004 12:03 PM
