What fmu disk with 450cc?
Old Oct 29, 2002 | 06:54 PM
Andrew 825SM's Avatar
Default What fmu disk with 450cc?
Using 450cc injectors, is a 4:1 disk suitable enough for 12-13 psi? I heard jinxproof had a past setup where he used 440cc , 12:1 fmu, and afc to tweak the fuel, but the fuel presure sounds too outrageous for high boost applications. Any ideas?
Old Oct 29, 2002 | 06:58 PM
MikeMAN's Avatar
Default Re: What fmu disk with 450cc? (NHB Fighter)
i would say 12:1 to be safe, but there is one below the 12:1 that lots have used just fine ( i just cant remember if its 10:1 or something)
mike
Old Oct 29, 2002 | 07:12 PM
sutrusu's Avatar
Default Re: What fmu disk with 450cc? (MikeMAN)
12:1 with 450s?!! he wouldn't even idle!!
you use an 8:1 with 310s... maybe a 6:1 or 4:1. not sure.
Old Oct 29, 2002 | 07:41 PM
HybridKOOP's Avatar
Default Re: What fmu disk with 450cc? (sutrusu)
Use a 6:1 and tune the fuel out.. better safe than sorry.
I'm running a 12:1 with 320cc injectors and no AFC... and I have a sluggish idle at times...
Old Oct 29, 2002 | 08:19 PM
turbosol's Avatar
Default Re: What fmu disk with 450cc? (HybridKOOP)
Use the 4:1 along with an afc and you will be fine. I've been using 370s with a 6:1 and afc with no problems at 13 psi, except traction. 13.7@109mph can we say absolutley no traction.
Old Oct 29, 2002 | 08:46 PM
SlowB16's Avatar
Default Re: What fmu disk with 450cc? (turbosol)
4:1 disk is the one you want
Old Oct 30, 2002 | 01:40 AM
ion_four's Avatar
actually, it would idle fine and be great until the computer went into closed loop and then it would bog like a madman and probably die.
do not be gay. use the VAFC and 450's. that is all you need. no other pieces.
Old Oct 30, 2002 | 02:44 AM
niedejb's Avatar
Default Re: What fmu disk with 450cc? (ion_four)
He'll need it to boost over the hacks capabilities of 10-11psi.
BoostedJeff
Oct 26, 2004 06:36 PM
cliff666
Jul 7, 2004 09:52 PM
turbo89civicb18hatch
Apr 5, 2004 10:41 AM
D16SI
Feb 5, 2003 06:10 PM
4gvtec
May 19, 2002 09:18 AM
