what fitting can i use
I NEED HELP REAL FAST.... im trying to find my tial fitting for the WG but cant find it what fitting can i buy so i can hook up my boost controller? trying to hit the dyno today...
whats the size and PN if possible
EDIT WILL THIS WORK
http://www.jegs.com/webapp/wcs...10019
Modified by 1Quikgsr at 10:14 PM 5/2/2007
Modified by 1Quikgsr at 12:40 AM 5/3/2007
EDIT WILL THIS WORK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1turboedEK »</TD></TR><TR><TD CLASS="quote">1/8 fitting ... thats what i used on mine.You can go to home depot and get a nipple!</TD></TR></TABLE>
thanks will do that did you use teflon also?
it is either 1/8 npt or 10mm x 1.0 depending on how new it is and if it is a 35 38 or a 44. all the 44's i have seen are 10mm x 1.0 banjo's. the older 38's are 10mm x 1.0 banjos, but the new ones are 1/8 npt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr »</TD></TR><TR><TD CLASS="quote">
thanks will do that did you use teflon also? </TD></TR></TABLE>
yea i use teflon on mine, works Perfectly!!!
Some of the ports are 10mmx1.0 thats the metric size, but u can still get the 1/8 in there also! i have done it plenty of times!
dont teflon the banjo. and if you use the 1/8 npt in the hole, chances are you are stuck with that so make sure you want to use that fitting. banjos are designed to have the aluminum washers do the sealing so dont use teflon on the banjo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">. and if you use the 1/8 npt in the hole, chances are you are stuck with that so make sure you want to use that fitting. .</TD></TR></TABLE>
Thats not true, i have taken my fitings out a few times and screwed htem back in, its easier to fin 1/8 fittings then it is too find the other fittings,so i guess its your choice!
thats why i said chances are. it depends on how far it is threaded in. it is a tapered thread verxux a straight thread. thats all.
Samuels
Feb 7, 2007 07:55 PM
