What else do I need to turbo
I have 1996 civic with d16y7. I have the turbo t3/t4 hybrid t04e , 38mm wastegate, manifold , oil lines with fittings, intercooler and piping. What else do I need. I was told that I needed hondata s200 with boost , p28 ecu, walbro fuel pump, RC engeering injecters 400 or 450 high imp or low?, OBDI to OBD2A adaper . I'm new to this stuff can you help?
if you're gonna run RC injectors. get saturated ones. the rc440's or rc550's will be more than enough for your setup i think. *with peak and hold injectors, you'll need resistor boxes.
if you're gonna run a p28, you'll need it chipped obviously for tuning. the obd2a to obd1 jumper harness will be needed.
you don't have to run hondata. but the s200b is a good choice if you want to. there's also crome and uberdata, which are free. check with your tuner to see what he is more comfortable with. if you're gonna tune, check out the software.
wideband o2 sensor is a good tool to have. and you didn't mention having a bov.
i see you're from florida. you should check with mtber from pherable.net. i think he does some tuning and chips ecu's. i'm sure he can help you out. i've heard good things about his services. GL
What are the saturated ones and the wideband o2 do for it.I have a bov but Im waiting to buy the downpipe. I dont know if the downpipe comes from the rightside or the leftside of the turbo? My boss at work is going to tune and chip it. My civic is the HX VTEC-E
slowassBubble
Engine Management and Tuning
Feb 22, 2012 06:17 PM
