what does everyone think
Old May 5, 2007 | 08:36 PM
indicajones's Avatar
Default what does everyone think
im rebuilding my car and was wonderin how much boost i can run for the most reliablity/longevity. here is my setup
b18b block
81.5mm je 10.1 pistons
eagle h beams
stock crank
oem bearings
650 injectors
hondata s200
t3/t04e "57 trim"
gsr head with itr valves
gsr cams
3 in catback
skunk 2 pro intake manifold
msd 6a ignition
im just about done putting the car back together and have to decide how much boost to run for when i get it tuned. idealy i would like to get as close to 300 hp as possable but im using stock sleeves. ive done a ton of research and i figured i would just like to hear what everyone thinks. this is a daily driver and is my only car at the moment. to be frank im going for reliablity here(if thats even possable). my friends at realtime and king think i should just run it at 7 no more than 10 psi. what does everyone here think. thnks a ton for your HELPFULL answers.
Old May 5, 2007 | 11:37 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: what does everyone think (indicajones)
dont go at it with a boost number in mind, think power. you dont want to know if you can push 7 psi or 10 psi, you want to know if you can push 250 or 300 whp ya know? you have hondata so take it to a reputable tuner and im sure they can pull close to 300 outta that thing safely all day long . Compression is a tad higher than ideal for FI, but that just makes it a little trickier to tune, not any less reliable. Im also a firm believer in a meth injection kit $200 especially for higher compression FI setups.
Old May 6, 2007 | 11:09 PM
bump a de boo
Old May 7, 2007 | 06:13 AM
Schister66's Avatar
Man U FTW
You should be able to make ~400whp on pump gas reliably....talk to your tuner and see what he's comfortable pushing it to....a lot of it depends on the gas you use as well..
Old May 7, 2007 | 06:50 AM
HiProfile's Avatar
Default Re: (Schister66)
A 10:1 ls/vtec and a 57trim@10psi should hit 300 no problem. A 9:1 ls/vtec and a 57trim@10psi will have a few percent less off-boost power, but more timing will make up for it in boost.
For 300 max you'd really be better off with a 60trim T3 combined with a gear-based boost controller & a 2.5bar MAP sensor. Much quicker spool, same power at a bit more psi, and 60trim T3's hold their value if you ever want to upgrade.
buky9
Apr 6, 2007 11:18 AM
Topdawgg
Aug 1, 2006 11:05 AM
Nikoli
May 30, 2004 07:31 AM
oMek
Feb 2, 2004 09:25 PM
4dGSR at work
Oct 31, 2001 08:19 AM
