What do you think this means? Please help......
I just did a compression test on my car. I took out all the spark plugs, took off the fuel injectors clips, and cranked 7-8 times with full throttle. I got this procedure from the honda manual. my compression numbers was:
183 175 178 180 (the 183 is the one closest to the distributor cap)
but I still have white smoke at idle, and white smoke, when I accelerate and let off the gas without hitting the clutch. then accelerate and then it puffs smoke. I'm thinking the turbo seals are going cause when I first put it on it was shooting oil out the compressor housing. Then my wastegate won't work and its spiking to 15 psi. So I'm hoping its just the turbo seals since I'm planning on replacing the turbo anyways.
So what do you all think?
Nick
Nick
T25 civic
Nov 14, 2002 06:21 PM
