What do you think about this setup? (Budget)
Ok here is what I plan to go with and some of the prices I found off Ebay and a few other used car part places, as well as jcwhitney and home depot. Tell me what you think.
B series Manifold- $200-$300 (revhard or drag)
intercooler-$200-$300 (thepartstrader.com)
t3 turbo-$150-$200 (Garret or AIResearch)
Downpipe w/o flex pipe=$100-$200 (Ebay)
Blow off valve-$100-$150 (any really)
Missing Link MAP Bypass-$50
Silicon Hoses-$30 (Home Depot)
Oil feed/return lines+ oil pan tap nipple-$50 (Home Depot)
charge pipes-$70 (www.jcwhitney.com)
wastegate-$100 (Ebay)
FMU=$80-100 (thepartstrader.com)
Total= $1130-$1550
Is there anything missing? Am I getting decent prices? I plan on running 8psi on my stock LS motor and plan on running a compression test to make sure everything is running fine. Thanks for your info.
Total= $1130-$1550
flamenco-T has great oil lines...i would buy from him...he sells them for like $45 shipped...
Bov---DSM 1G BOV=$50 shipped
buy a revhard mani...not a drag one...they suck in comparison
good luck w/ that downpipe from ebay...i dont trust them for ****
internal WG????
i dont know what car you have so i dont know if those turbos are good for you
wg i wouldnt do anything but a tial...ive only heard of bad things w/ deltagates and such....
you have the piping listed...what about cuplers? are you welding it all?
injectors?
how many psi are you planning on boosting...this post is very incomplete...but i tried...good luck...
internal WG????
injectors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig »</TD></TR><TR><TD CLASS="quote">i dont know what car you have...</TD></TR></TABLE>
Like I said above, the car has an LS motor.
injectors?
I won't need them for now.
how many psi are you planning on boosting...this post is very incomplete...but i tried...good luck...</TD></TR></TABLE>
Like I said in the first post, it's going to be running 8psi, with a vortech FMU, so injectors are not required. I also put $100 for the wastegate too, so it's not internal. But thanks for the BOV tip, that'll definately help my budget.
Oh and the couplers are included as the item- silicon hoses, which will cost around $30-$35
injectors?
You don't want to use the home depot rubber hose, it'll blow right off, especially if you use it to hold the charge pipe to the turbo. And if you tighten it down really tight, it'll rip.
http://www.johnnyracecar.com for a nice intercooler
You should get a nice Walbro intank fuel pump if you're gonna run 8 PSI. You can get it for around $100
Oh and in case your wondering where the piping is from exactly (Got a few IM's) http://www.jcwhitney.com/webap...10101.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdog19 »</TD></TR><TR><TD CLASS="quote">Ok here is what I plan to go with and some of the prices I found off Ebay and a few other used car part places, as well as jcwhitney and home depot. Tell me what you think.
Blow off valve-$100-$150 (any really) dsm 50
Silicon Hoses-$30 (Home Depot) get real silicone couplings
Oil feed/return lines+ oil pan tap nipple-$50 (Home Depot) buy from flamenco
wastegate-$100 (Ebay)ditch and do vafc hack
FMU=$80-100 (thepartstrader.com) ditch it
Total= $1130-$1550
Is there anything missing? Am I getting decent prices? I plan on running 8psi on my stock LS motor and plan on running a compression test to make sure everything is running fine. Thanks for your info.</TD></TR></TABLE>
Total= $1130-$1550
Where should I get the hoses from? If possible I would like to get them in black, or anything that just looks stock. Thanks for the advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdog19 »</TD></TR><TR><TD CLASS="quote">Why should I do the VAFC hack? Won't it end up costing more?</TD></TR></TABLE>
Your avatar is kinda creepy...whats Ronald doing? Looks like hes gonna hit that chick IDB. I think you have a pretty good budget setup, I'd definitely do the walboro internal fuel pump. The fmu will make it real rich, maybe you could upgrade the fuel management system and make some real power down the line.
Yeah the FMU has always what I have never wanted to have in my car but for what it's worth I think it's a decent place to start. Thanks for your info though, good stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdog19 »</TD></TR><TR><TD CLASS="quote">Yeah the FMU has always what I have never wanted to have in my car but for what it's worth I think it's a decent place to start. Thanks for your info though, good stuff</TD></TR></TABLE>
now whats up with Ronald?
I would do this:
Buy a turbo with an internal wastegate.
you save $100
Dont buy the Map bypass
you save $50
buy a used hondata blue box that should be well worth the extra horsepower, peace of mind and extra room to grow on.
you save $100
you save $50
I just watched "IT" last night and had a few good laughs with my clown buddies so I'm kinda crazy right now AHHAAHA. Beep Beep RICHIE!
Anyways, what exactly is a hondata blue box? I was thinking about a 2b when I thought I had money but now i'm confused. I wanted to stay clear of that for now because of the OBDII-->OBDI harness and the ECU, which means too much money than I can afford for now.
--unrelated--
anyone know where a vacuum leak is likely to occur on a GSR w/ skunk 2 IM and JG throttle body? revving idle---
--unrelated--
here's my 2 cents:
The Home Depot Hose connectors won't relly work, they're made out of soft rubber, I found cuts in my 3 times already. (less than 4 PSI). Pay alittle more and get the good stuff, it will save you money in the long run and headaches.
there's a company in here in VA that makes Custom Intercoolers, I paid $300 for mine (31x6x3), All hand made (except the core), the advantage of getting from him is you'd get a new one.
got to: http://www.speedpartsrus.com
or e-mail Anthony : customcoach@comcast.net
FONK
Mar 15, 2006 06:07 AM
