what do you think????
Old Dec 26, 2007 | 05:51 PM
93blacksol4life's Avatar
Default what do you think????
I like to know if this turbo good to use with a B20B
T3/60-1 AR70 BIG SHAFT 63 TRIM T3 FLANGE TURBO CHARGER
ar70, huge compressor, big shaft 450hp max, MAX PSI CAPACITY is 30 psi
Old Dec 26, 2007 | 05:59 PM
boosstboy's Avatar
Default Re: what do you think???? (93blacksol4life)
what hp are you looking at getting from your setup, built not built?
Old Dec 26, 2007 | 06:03 PM
Default Re: what do you think???? (boosstboy)
new stock B20B haven't got it in but i'd to use this turbo for the new motor,i had b16a turboed but no #'s for it,i got a 13.995 in the 1/4 mile in a delsol
Old Dec 26, 2007 | 06:05 PM
Schister66's Avatar
Man U FTW
If you're running a stock B20b, then its probably not a great turbo for your goals. B20's have weaker sleeves than the other B series blocks and aren't good for much more than 300ish whp. IMO, get a turbo that spools faster so you have a more usable powerband
Old Dec 26, 2007 | 09:21 PM
JDMs1eeper's Avatar
Default Re: (Schister66)
itll work fine.
B20's can be boosted, just stay below 300whp on a "real" tune.
Old Dec 26, 2007 | 09:46 PM
Schister66's Avatar
Man U FTW
Default Re: (JDMs1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">itll work fine.
B20's can be boosted, just stay below 300whp on a "real" tune.</TD></TR></TABLE>
I agree, BUT why buy a turbo that is overkill for your setup?? Lag isnt exactly a desirable thing....especially on the street
Old Dec 26, 2007 | 09:57 PM
93CX's Avatar
eBay turbo
Old Dec 26, 2007 | 11:20 PM
mrbsponge's Avatar
Default Re: (93CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">eBay turbo </TD></TR></TABLE>
you got to it before me
Old Dec 31, 2007 | 02:05 PM
Default Re: (mrbsponge)
yes ebay but not SSACRAP
sleeving motor
Old Dec 31, 2007 | 03:22 PM
LS AzZkIkr's Avatar
it will spool fine. its a tad bigger than my last turbo and that was full boost (9 psi) and it was all good. i have seen a sleeve bearing t77 on a b16 and it was full boost at vtec crossover. and lag isnt all that bad on the street considering power + fwd = wheelspin. i would get it if its a good enough deal.
Old Dec 31, 2007 | 03:48 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
i kinda like a little lag IMO for the street ... i like that turbo ..do it i'm going with a either the sc-61 or the 60-1 for my b16 i think it will work out great for you
Old Dec 31, 2007 | 04:31 PM
LS AzZkIkr's Avatar
Default Re: (Throwdown)
same here. i want traction at first and then power later when i can use it. to me lag is not that important for a few reasons. 1. driving around it will feel like n/a car until i get on it. 2. at the track lag doesnt really matter because if your set up is SET UP and you can drive there will be no problem. a 2 step set at the right rpm will let you launch at full boost.
Old Dec 31, 2007 | 06:23 PM
simply's Avatar
Default Re: (LS AzZkIkr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS AzZkIkr &raquo;</TD></TR><TR><TD CLASS="quote">same here. i want traction at first and then power later when i can use it. to me lag is not that important for a few reasons. 1. driving around it will feel like n/a car until i get on it. 2. at the track lag doesnt really matter because if your set up is SET UP and you can drive there will be no problem. a 2 step set at the right rpm will let you launch at full boost.</TD></TR></TABLE>
ehhhh.... i dont think a step will gwt you full boost at launch
Old Dec 31, 2007 | 08:32 PM
Throwdown's Avatar
Default Re: (simply)
i wouldn't want to boost very much off the line either i think a lower psi would be enough.... but i do agree with the rest of your statement LS AzZkIkr...
devney
Mar 24, 2010 11:04 AM
JdM_Eg_6
Sep 13, 2004 04:27 PM
Tushner
Mar 3, 2004 09:00 AM
SPOON_BeIgHtEeNsEe
Jan 28, 2004 05:17 PM
qsilver074
Oct 23, 2003 04:35 PM
