timing on nitrous set up?
Old Dec 31, 2007 | 08:33 PM
suprgato's Avatar
Default timing on nitrous set up?
I just finished building a gsr with ITR pistons and a 7lb flywheel, I'm new to the nitrous seen I have a zex wet kit with a 75 shot that I want to put on after the break-in so my question is do I have to retard the timing and if so how much or can I just throw on an fmu?
Old Dec 31, 2007 | 09:05 PM
Joseph Davis's Avatar
Default Re: timing on nitrous set up? (suprgato)
An FMU has nothing to do with timing.
If you can control the nitrous via ECU/standalone, or control ignition timing anyway, you will find that you need to take a lot more timing out in the lower rpms. I'd start at (typical figures, your results can and most probably will vary) 8 degrees @ 3000 rpm and taper up to 3 degrees @ revlimit, see what that does for you.
IemSpooled219
May 13, 2009 02:57 PM
Mr. Self Destruct
Mar 20, 2008 06:13 AM
Tippyman
Nov 22, 2005 09:11 PM
SOHC_MShue
Nov 30, 2003 07:54 PM
Pinhead
Oct 12, 2001 12:11 PM
