What To Do With These Pistons?
Old 04-23-2005, 02:26 PM
Vtec92Civic's Avatar
Default What To Do With These Pistons?
Thinking of picking up this setup off a friend. It's a Longblock but taken apart. The pistons got some minor scarring on the side, but not sure if I can re-use them or not. One pistons is not re-usable for sure but the rest not sure.
If I get it I plan on replacing some stuff:
rod bearings
water pump
headgasket
cam seals
timing belt
anything else?
It's a LS Vtec . . . . . B16 Head LS Bottom Eagle Rods SRP Pistons. Anything else u guys would recommend? It's gona be boosted. Any suggestions would be great . . . this is gona be a little side project for me
Thanks Guys . . . . i'll try and get pics of the pistons. Also is there a way to tell if the crank is bad? The guy said it is, but I find it hard to believe that the crank is rubbish just from a spun rod bearing.
Old 04-23-2005, 04:11 PM
N20civicB18's Avatar
Default Re: What To Do With These Pistons? (Vtec92Civic)
ebay
Old 04-23-2005, 07:54 PM
s2kdre's Avatar
Default Re: What To Do With These Pistons? (N20civicB18)
the piston is messed up for a reason, the sleeve might be warped.
Old 04-24-2005, 01:38 PM
Default Re: What To Do With These Pistons? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">the piston is messed up for a reason, the sleeve might be warped.</TD></TR></TABLE>
well is it a fixable issue if the sleeve is warped or is it totally garbage. The block was honed I know that, but I just figure I ask these questions on here for a second opinion so I don't buy a bunch of junk you know what I mean?
Any info is helpful to me, just trying to make a decision before it sells, but I don't want to buy stuff that is useless or worthless.
The rods are still fine, one piston just has some scarring . . . . not missing chunks of metal just some scratches, head looks perfect, just my concern is the pistons, and the crank, and well possibly the block
Old 04-25-2005, 02:26 PM
TTT
carlossolorzano
06-09-2012 10:42 PM
rich7777
02-23-2010 03:50 PM
fmfkid250
11
11-29-2006 05:58 AM
hondadriver
09-30-2006 02:58 AM
ysrhatch
08-27-2001 07:10 AM
Quick Reply: What To Do With These Pistons?
