Which guages are most useful?
Old Nov 3, 2001 | 09:32 PM
slewis's Avatar
New User
Default Which guages are most useful?
There are lots of guages you can get... But which are the most useful?
I'm trying to decide what three guages I want. Right now I'm settled on the GReddy boost, oil pressure, and EGT guages. Someone suggested to me that A/F ratio is useless, or rather only useful if when using a wideband guage during tuning...
Thoughts?
Old Nov 3, 2001 | 10:24 PM
Anthony K's Avatar
New User
Default Re: Which guages are most useful? (slewis)
I think most people have an A/F, Boost, and EGT if they have three gauges. A/F is really only useful to make sure that you're not running lean at WOT. This can actually be very helpful. I don't think it's usually a terribly accurate gauge but it does the job.
Old Nov 3, 2001 | 10:35 PM
Incognito's Avatar
Default Re: Which guages are most useful? (Anthony K)
Boost, EGT and oil pressure.
Old Nov 3, 2001 | 11:08 PM
accordfreak's Avatar
Default Re: Which guages are most useful? (Incognito)
what's an EGT guage?
[Modified by accordfreak, 8:10 AM 11/4/2001]
Old Nov 3, 2001 | 11:19 PM
degradated's Avatar
New User
Default Re: Which guages are most useful? (accordfreak)
EGT = exhaust gas temperature
Good for diagnostics and gives you a clue if you're running lean or not by how hot the gasses get coming from the exhaust manifold.
Old Nov 4, 2001 | 12:49 AM
greyzone's Avatar
Default Re: Which guages are most useful? (degradated)
Boost is a must and FUEL PRESSURE is a must. One of the quickest ways to kill your engine is to loose fuel pressure, run it lean and blow the motor. Fuel pressure gauge is one of the better ways of monitoring this, EGT gauges are not real accurate, nor are A/F gauges but it is good to have at least one of those.
If you had four, it these would be the four good ones to go with:
1) Boost
2) Fuel Pressure
3) EGT
AND
4) A/F
THose guages are going to monitor the most crucial aspects of a turbo engine and help you make sure you not RUNNING LEAN, which is death to the turbo engine
Old Nov 4, 2001 | 03:27 AM
GruvyTune's Avatar
New User
Default Re: Which guages are most useful? (greyzone)
Boost
EGT
Oil Pressure
All are electronic Greddy's
Old Nov 4, 2001 | 08:12 AM
AutoSol's Avatar
New User
greyzone: you'd say fuel pressure over oil pressure guage? I'm not sure which is more likely, an oil leak or have the fuel pump go bad. My guess would be an oil leak? How is oil pressure monitored anyway?
degradated: so suppose you had the GReddy EGT guage, does the temp vary with the ambient temp? If it starts to increase a lot, that indicates you're going lean?
Now I can't decide if I should stick with boost,EGT,oil pressure or go boost,EGT,A/F.. I can only fit three for now... Actually, someone makes a digital A/F guage, that is kind of square and mounts somewhere else (not in a guage pod), but I forget who...
Old Nov 4, 2001 | 09:29 AM
smoothludey2's Avatar
New User
Default Re: Which guages are most useful? (AutoSol)
greyzone is absolutely correct....fuel pressure is a must for every boosted vehicle...fuel delivery is overlooked alot, but it's the most important aspect of maintaining a healthy running boosted vehicle. Oil pressure? EGT? If you are boosting checking the oil level every now and then should be routine and an EGT gauge might tell u if you're running too lean but the fuel pressure gauge will prolly give you an earlier indication of a problem. I'm not boosting YET, but the only gauges i'm getting are boost and fuel pressure.
Old Nov 4, 2001 | 09:44 AM
greyzone's Avatar
Default Re: Which guages are most useful? (smoothludey2)
Word. Those are the only two gauges I have.
All else is taken care of by good tunning and regular checks of my oil level.
Sudden spontaneous loss of oil rarely occurs. Many things can cause loss of FP, not just the pump going bad; ie, vacuum leaks, line clogs, line leaks/breaks...lose FP under hard boost and you're burnt toast FAST. (By the way: never run below 1/8th tank and if the big rig is at the gas station pumping in the gas delivery dont fill up, get gas somewhere else. Both situations cause problems with chunky particles in gas, which leads to clogged fuel lines/filters.)
If its a decision between EGT and A/F, go with EGT (GReddy) its MUCH less expensive and will help indicate lean under boost. HOWEVER, those who rely on those gauges often blow motors since they are semi-accurate at best. The dyno is always the best bet for issues of rich/lean.
[Modified by greyzone, 6:50 PM 11/4/2001]
Old Nov 4, 2001 | 09:50 AM
SIK IN DA HED's Avatar
New User
i second that!!
Old Nov 4, 2001 | 11:01 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
hey steve! it's kevin...hurry up and get your boost on!
Old Nov 4, 2001 | 11:46 AM
turbopanda's Avatar
Default Re: Which guages are most useful? (the sneezer EG)
I'd have to go for fuel press, exhaust temp, and boost, as well as an A/F meter (not the autometer one, they suck). I think reading an A/F meter would be much easier than trying to guess what the EGT has to read to be considered "okay". All these meters should be electronic, especially the fuel press, coz the last thing you want is a mechanical fuel press gauge leaking in your car. I've had a friend who used an autometer fuel press gauge and mounted it in the dashboard inside his car. A little fire started because the fuel line that goes to the meter was leaking inside the car and there was a short circuit somewhere behind the console. Lucky he had a small fire extinguisher in his car. That's another thing every turbocharged car should have. A small fire extinguisher!!
Old Nov 4, 2001 | 12:03 PM
JM Performance's Avatar
Default Re: Which guages are most useful? (nathan's boosted civic)
Damn...I've NEVER heard of someone using those things before. Usually its just ricers that carry them.
Old Nov 4, 2001 | 01:19 PM
LsTurbo91's Avatar
Default Re: Which guages are most useful? (00SilverLS)
I'd say boost, egt, air/fuel gauge (closed loop tuning), fuel pressure if you have an FMU.
Old Nov 4, 2001 | 02:25 PM
AutoSol's Avatar
New User
Default Re: Which guages are most useful? (LsTurbo91)
Thanks everyone! I'm gonna go with Boost,EGT,and Fuel Pressure. Looks I'll have to pay retail though, I'm not patient enough to find good deals
I won't have an FMU or upgraded fuel stuff (just stock LS injectors and fuel rail), but I think I'll be safe enough at 6psi for starters. I'd like to get an oil cooler, but geesh their expensive.
Old Nov 4, 2001 | 02:32 PM
retail? ha. go to http://www.aieonline.com they sell all GReddy **** 28% off of list.
frostcivic
Aug 5, 2004 02:31 PM
Patron
Dec 20, 2003 01:57 PM
Snafu-Si
Jul 7, 2002 11:48 AM
E Swift
Jun 5, 2002 08:34 PM
cyan1de
Dec 11, 2001 10:30 AM
