What to do to stripped threads on the turbo?
I have a t3/t4 that has 2 stripped threads on the exh. side where the DP bolts up. They guys at napa suggested a heli-coil but I think that it would back out or wouldnt last because of the heat. What should I do? tia
Blaze
Blaze
Are all the threads stripped out or are just the top few screwed up?
If its the latter you can buy a cheap tap & die set from http://www.harborfreight.com and retap it.
Ive been there before. If you tackle it yourself, it can be done w/ a selection of easy-outs, a drill, and a tap to do a final clean up. Goodluck.
I have tapped and threaded a few things before. I dunno how excited I am to try it on my turbo.... thanks for all the help.... I believe its an 8mm bolt, should I try tapping for a 10mm bolt?
Blaze
Blaze
suprisingly those coils work pretty well, i used to use them on my oil pans and such, they withstand heat very well. but you can also retap, which i am a fan of as well. i've retapped quite a lot of threads, i think that works best also. plus if you have your own kit, it is free, just time consuming/somewhat.
SOHC_MShue
Nov 20, 2004 05:44 PM
