what to do with this sensor?
Old Dec 4, 2006 | 12:40 PM
jrs2ksi's Avatar
Default what to do with this sensor?
ok....I'm going to install a trubo on my civic, and I don't know what to do with this sensor wire thats in my intake tube right now. I dont want to throw any check engine lights when i have my turbo.thanks
Old Dec 4, 2006 | 01:04 PM
jrs2ksi's Avatar
Default Re: what to do with this sensor? (jrs2ksi)
Old Dec 4, 2006 | 03:00 PM
TDautowerkes's Avatar
that is the intake air temp sensor....
depending on your EMS you might be able to run a gm or aem iat sensor which is threaded and wont pop out under boost
Old Dec 4, 2006 | 03:04 PM
jrs2ksi's Avatar
Default Re: what to do with this sensor? (TDautowerkes)
thanks a lot.....where could i find one of those threaded ones???
Old Dec 4, 2006 | 03:46 PM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrs2ksi &raquo;</TD></TR><TR><TD CLASS="quote">thanks a lot.....where could i find one of those threaded ones???</TD></TR></TABLE>google works well
Old Dec 4, 2006 | 04:19 PM
qfast817's Avatar
Default Re: what to do with this sensor? (ryan89crx)
i didnt hook mine in the charge pipe, i let it pick up outside temp
Old Dec 5, 2006 | 12:00 AM
dizzyek's Avatar
Default Re: what to do with this sensor? (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">i didnt hook mine in the charge pipe, i let it pick up outside temp</TD></TR></TABLE>
This is how i have mine too I heard this is bad though?????
Old Dec 5, 2006 | 12:28 AM
F20Cteg's Avatar
Default Re: what to do with this sensor? (dizzyek)
Definitely not a good idea.
Tuned a friend's car like that and the "reported" temps really flucuate making it really hard to tune.
Switched back to the Z6 mani and the tuning was cake.
Old Dec 5, 2006 | 02:28 AM
RACEPAK's Avatar
Default Re: what to do with this sensor? (F20Cteg)
get a obd1 sensor and connector. make a flange for it and weld it to your air filter pipe.
Old Dec 5, 2006 | 03:55 AM
EFvtec Yo!'s Avatar
I have that same issue with my boosted b16. Because my old SOHC had that sensor in the intake pipe also. Now i have a b16 could i just use the iat sensor on the b16 manifold or do i still need to keep that sensor in the charge pipe?
Old Dec 5, 2006 | 03:58 AM
rmcdaniels's Avatar
I drilled a hole in my charge pipe and put the sensor in it. It only popped out occasionally when I went over 20 PSI of boost, so I put a zip-tie over it and it never popped out again.
Old Dec 5, 2006 | 06:17 AM
RACEPAK's Avatar
Default Re: (EFvtec Yo!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFvtec Yo! &raquo;</TD></TR><TR><TD CLASS="quote">I have that same issue with my boosted b16. Because my old SOHC had that sensor in the intake pipe also. Now i have a b16 could i just use the iat sensor on the b16 manifold or do i still need to keep that sensor in the charge pipe?</TD></TR></TABLE>
yes you can use it.
Old Dec 5, 2006 | 06:23 AM
SOHC_MShue's Avatar
its real simple. Drill a hole and use that same grommet that came with your intake. Thats what i did and mine has never popped out in 3 years even with around 15psi
Old Dec 5, 2006 | 01:48 PM
jrs2ksi's Avatar
Default Re: what to do with this sensor? (SOHC_MShue)
well, ill try drilling it into my charge pipe. I'm planning on runnig no more then 10 psi so i think itshould be fine
ROOSTER.
Jan 31, 2014 05:42 PM
berb_15
Sep 15, 2007 05:09 PM
civic_tuned
Jul 1, 2007 04:42 PM
jnuanz382
Honda Civic (2006 - 2015)
Apr 28, 2007 09:16 PM
1baddcivicsi
Aug 22, 2006 06:33 PM
