what to do...
Ive been wondering what i could do to not only feed my turbo but also put a oil pressure sender somewhere on my motor. i know people are using sandwich plates but would a sandwich plate also be wide enough to screw a sender on?
I could use the factory oil pressure sender location but i dont know if i can find an adapter with 4 orfaces to screw into the block, feed the turbo,put my pressure sender to run to a guage on and put the factory sender on.......? is the factory sender necessary? i have an obd1 car and id imagine it would throw a code... |
Re: what to do... (nboost)
if you dont want to run a sandwich then get a fitting and run a single line to a 4 way T on the firewall and you will be fine. I got my brass 4 way at homedepot https://honda-tech.com/forums/images...es/emsmile.gif
I used a sandwich and remote mounted my oil pressure sender on the firewall. I got some 100+ PSI rated fuel injector line from NAPA and used a hose barb on either end.
