What diameter oil feed line?
Old Aug 20, 2002 | 08:28 AM
mlhardy's Avatar
Default What diameter oil feed line?
I am cusious as to what diameter oil feed line you guys are using, I am using the line that comes with the GReddy kit and it seems to be pushing way to much oil. I smoke when I stop and idle after running for very long. The turbo is pushing oil into the charge piping and I don't have any play in it so it is good. The head gasket is also good so I have came to the conclusion that this is the problem. What do you guys think?
Old Aug 20, 2002 | 08:32 AM
RGAZ's Avatar
New User
Default Re: What diameter oil feed line? (mlhardy)
AN4 is what I use. Maybe you should look at your drain line being too small, not the feed line too big.
Randy
DSF's Avatar
DSF
https://honda-tech.com/zerosearch
https://honda-tech.com/zerothread?id=232145
https://honda-tech.com/zerothread?id=222759
https://honda-tech.com/zerothread?id=168605
https://honda-tech.com/zerothread?id=158018
[Modified by DSF, 12:35 PM 8/20/2002]
Old Aug 20, 2002 | 08:36 AM
ArizonaTurbo's Avatar
-3 A/N shoudl be more than sufficient!
Old Aug 20, 2002 | 08:50 AM
mlhardy's Avatar
Default Re: What diameter oil feed line? (TurbochargedSER)
Thanks for the help guys, especially the links. I hane a 4a/n now and that I think is the problem. I guess it is time to size it down before my seals are bad.
Old Aug 20, 2002 | 08:55 AM
JPowers's Avatar
My feed line leaked at the turbo since the day it was installed. Put in a new banjo fitting and it still leaks! Why do they use these stupid banjo fittings? I hate them! Greddy told me -3AN so that's what I'm about to put on my car. The outside diameter of the Greddy hose is quite a bit larger than the -3AN hose I just received, I'm hoping this is because of insulation and not due to the inside diameter being larger. The inside diameter of my -3AN hose is 3.5mm. Does anyone have a Greddy feed line lying around they can measure the inside of?
PinoyDelS0l
Aug 30, 2009 12:43 AM
eg6_lsi
Mar 18, 2004 04:46 PM
delslowh23
Feb 28, 2004 04:59 PM
rpm9100
Jun 13, 2003 03:55 PM
PrecisionH23a
Jun 16, 2002 07:53 PM
