What crank do you use?
Old Apr 23, 2003 | 08:46 AM
Dorikamu's Avatar
Default What crank do you use?
Running around 15psi max, usually on 10psi.
Is stock crank good enuf for that? WTB, how much hp is the stock crank good for?
Old Apr 23, 2003 | 08:55 AM
E-Rok's Avatar
EPIC TUNING
Default Re: What crank do you use? (chusai)
stock crank will handle pretty much anythign you dish at it.
Old Apr 23, 2003 | 08:57 AM
gumbybum's Avatar
Default Re: What crank do you use? (rewsnaeht)
hey but what about the bearings? would stock be ok??
Old Apr 23, 2003 | 09:13 AM
Dorikamu's Avatar
Default Re: What crank do you use? (gumbybum)
I have heard pple using ACL(they are suppose to be cheaper and better).. anyone?
Old Apr 23, 2003 | 12:24 PM
boosted3g's Avatar
I always use stock. As far as the ACL bearing, my machinst thinks they are the best bearing he has ever seen and we have never had a problem with them. Plus they are less than half the price of stockers
Old Apr 23, 2003 | 12:31 PM
Gravy's Avatar
Default Re: What crank do you use? (boosted3g)
our shop car made 689 to the wheels on a stock h22 crank with cleavite bearings.
T-sohctec's Avatar
With today's machining tolerances the bearings you use don't really make a damn bit of difference. I know I am gonna catch alot of flak for that statement but it's true.
I've used ACL, Clevite & OEM they all meet the spec that they are supposed to.
If you wanna get some silly precicion you can plastigauge everything then order OEM bearings that will give you EXACTLY a .0015 oil clearance on every main.
Personally I don't give a **** if I have a .0008 variance.
As far as a honda crank, there is none better. Plenty of people go up to and PAST 500WHP on a stock crank. They are Forged and will take all the abuse you can throw at them.
Old Apr 23, 2003 | 01:15 PM
sweet's Avatar
Default Re: What crank do you use? (T-sohctec)
the stock Honda crank can handle quite a bit of power before giving out. and the OEM bearings are what i use. just gauge them as close to .0015 for the #1, 2, 4 and 5 main journals as was mentioned and you should be fine. and .0017 for the #3 main. that's close to the middle of the clearance range, just a hair tighter than the middle. as long as the journal surfaces are good then just carefully clean them up. if the motor is really high mileage some of the journals may be out-of-round, but most likely not.
i've heard from most that ACL and Clevite bearings are just as good as the OEM.
gdrum
Apr 6, 2017 06:57 AM
GReddy SI
Jun 6, 2012 09:31 PM
rich7777
Feb 17, 2010 09:38 AM
DanishR
Oct 7, 2007 07:41 PM
mike93eh
Jan 12, 2006 07:27 PM
