what could be the cause??
Old Mar 17, 2004 | 03:27 PM
birz's Avatar
Default what could be the cause??
My engine (B18B1) has been rebuilt with ross pistons (8.8:1cr), eagle rods,, bore has change to 81.5mm, my turbo is a TD05 from a talon fuel management is SMC+.
Before I used to boost at 8 psi and I did'nt have any device to retard timing so it was set at 8 degree, now I have a BTM 1 degree of reatard per boost and it is set at 16 degrees on the distributor,,,,, the problem is: it only boosts at 5 psi use to be 8,, I dont have any boost controller. And my vaccum seems fine 22in.Hg at idle
what could be the problem??
thanks for the help.
Old Mar 17, 2004 | 04:10 PM
RyanEJ8's Avatar
Default Re: what could be the cause?? (birz)
Check for a leak in your piping.
Old Mar 17, 2004 | 04:11 PM
birz's Avatar
help plz
Old Mar 17, 2004 | 05:37 PM
scttydb411's Avatar
why pull that much timing? i run stock timing and retard 1/3 degree per pound of boost and it's fine. try 1/2 degree per pound of boost and tune it via wideband.
Old Mar 18, 2004 | 04:13 AM
birz's Avatar
Default Re: (scttydb411)
you think it could be due to the timing being to retarded? could it be the cause?
Old Mar 18, 2004 | 09:50 AM
birz's Avatar
come on guys aren't you Honda gurus?
ghost14
Engine Management and Tuning
Sep 18, 2012 11:30 AM
Btothe3rdDegree
Nov 18, 2004 01:34 PM
pipes
Feb 20, 2004 09:19 AM
BoostedD15B7
Jan 25, 2004 08:44 AM
willyboyK20
Oct 30, 2002 09:50 PM
